Question about Other Sports Afield Executive Gun Safe Vault SA6024 60x24x20 Black
How to program an sa6024 sport afield safe - Other Sports Afield Executive Gun Safe Vault SA6024 60x24x20 Black
User manual for sports afield safe
need a model #...
find the product here and you can download the manuel......
http://saproducts.com/
Jan 06, 2018 | Home Security
I have a sports afield gun safe but do not have the codes ,the safe is open
There is normally a button to reset the codes. It is good you have it open. Contact the maker direct by phone.
Contact Sports Afield Gun Safes
Dec 13, 2017 | Locks & Locksmithing
If there is a power failure will my Sports Afield safe still open?
don't know try putting in the model and numbers so we can help do a search for you
Oct 10, 2017 | Power Home Security
Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
Jun 30, 2014 | Other Sports Afield Executive Gun Safe...
Does archery considered being a dangerous sport?
Generally, archery considered being a safe sport when doing it right. Certified target archery instruction programs have very low accident and injury rates.
Aug 26, 2012 | Betsey Johnson Archery
I need to replace the electrical lead and pedal to connect to my elna machine model 1010 , any idea where to look?
try www.sewingpartsonline.com for this, I'm assuming you are in the USA and need 110V foot control and lead? If not and you need a 240V cable, might need to try further afield.
www.sewusa.com is also a good source for sewing machine parts
Mar 10, 2011 | Elna 1010
Carver one e grip has no power button. how do i get it 2 work?
Look really close at the front of the grip. There should be a couple of small holes and one has the power button recessed inside. Tippmann.com should have a schematic on it and the programming instructions as well for setting/changing modes.
Enjoy!!!
Play hard, play safe, play with honor!
8^)
Dec 25, 2010 | Tippmann A 5 Standard Paintball Gun
Central locking not working with remote key
Although its an "86" to play it safe Take it back to dealer there may be a reset program involved with this.
Jul 08, 2010 | 1986 Renault Sport
Uninstall
Use the uninstall program that just about every piece of software comes with. It'll be in the same location within your start menu that the game is located within the EA sports folder (or however it's organized). If it's not there, then go to your control panel and find add and remove software. From there, you should be able to locate Tiger Woods and double click it. It'll take you through the whole process.
Jun 05, 2010 | EA Sports Tiger Woods PGA Tour 2008 for...
Hi my Philips go gear type is SA 60xx...it has important recordings to me....but it couldnt recognize by my computer because i do not have driver software for it...please tell me how i download that driver...
An overview for all models GoGear SA60xx on this site:
http://www.search.philips.com/search/search?q=SA60&s=all&l=global&h=all
Select your model on the page above e.g. SA6024/02:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA6024/02&slg=en&scy=GB
Once selected the correct model, the corresponding
"Software and drivers" can be selected in the left column.
A new page will open with all matching and available downloads:
software for the computer, firmware and updates for the device.
Oct 12, 2009 | Philips GoGear SA178 MP3 Player
Other Sports Afield Executive Gun Safe Vault SA6024 60x24x20 Black Logo
188 people viewed this question
Top Other Home Security Experts
Lawrence Oravetz
Are you an Other Home Security Expert? Answer questions, earn points and help others
