Question about Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts
Can I use the TA2ANWC thermostat with a fahrenheat baseboard heater model # F25408
3 Suggested Answers
Accurate Joe
  • 61 Answers
SOURCE: add line thermostat to fahrenheat space heater
Just disconnect the other thermostat. You can leave it there just disconnet the wires
Posted on Nov 30, 2008
artisan_ent
SOURCE: I need to know how to wire the thermostat to the
if its 240v your line in to the thermostat is two hots (black and white, white in 240 is no longer nuetral and must be marked as hot) and a green/bare ground from the panel, these usually connect to the reds on the double pole thermostat. the load out is usually two black wires which are then connected to the black and white wires of the baseboard unit.
Posted on Aug 23, 2009
My three pole switch burned out on the baseboard heater. Need replacement switch. Thanks
Representative from Fahrenheat contacted me and is mailing me the part
needed. Thanks for the web site.
Dec 23, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Electric baseboard heater hums while running
is a 60 cycle hum, resonating with the power. check screws that mount it nothing to really worry about
Dec 31, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Do the Fahrenheat Hydronic Baseboard heaters work well?
No i would not recomend this model ! if you can stay away from baseboard heat alltogether it is an energy waster!,somthing that moves the air would be a much better choise
Dec 10, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Fahrenheat baseboard heater
no this is normal for this type of heater during its run time,I hope this makes you feek a little better!
Oct 24, 2008 | Fahrenheat Built-In Baseboard Thermostat...
How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
How do I wire up my fahrenheat F25408 baseboar heater?
Baseboard heaters are easy to hitch up. You can have a wall mounted thermostat or an integral thermostat. The diagram I have is for the integral thermostat. Follow the diagram and it should work.
Nov 28, 2007 | Fahrenheat Electric Convector Baseboard...
Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts Logo
132 people viewed this question
Top Marley Heating & Cooling Experts
paulcarew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
