Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Mounting Deck belt for Flymo LT125/38 - Craftsman 20 Hp 42" Deck Lawn Tractor
How can I hook up the snowblower attachment?
if its a garden tractor then you will first need to remove the mowing deck , this is easy if you have something to run front wheels up on to allow you room to pull deck out the side ,set deck height all the way down, save the drive belt . save the deck pins . locate the front chassis mounting arms and drive up to blower allow rear mounting arms to go between the two front wheels till the back of blower meets the front of chassis mounting arms (tight fit) install pins at all four points of contact , install belt to blower and front pto of machine (install any guards for belt) then raise blower from ground with deck height adjustment lever (it might feel heavier) test it to prove good contact your done
if its a three point (this is the reason I own one know) you back up to blower lower the mounting arms , engage the quick pins , install the drive shaft between the blower and machine with a quick spring snap , connect top link to tractor get back in seat and start machine raise three point an go !!
Jan 19, 2016 | Garden
Can i replace an ariens 46in mowing deck with a 42in deck
as long as the mounting hardware is the same. and you will have to use a different belt
Oct 28, 2014 | Ariens 46in Lawn Tractor 22hp Briggs ES
HOW DO YOU CHANGE THE DRIVE BELT ON A FLYMO 360
Your question is in the video game consoles categories???
If you actually have a Flymo 360 lawnmower you will find a link below to the users manual. However I looked at the manual and it appears to be direct drive ie. no belt. http://www.flymo.com/ddoc/flyo/flyo2012_gben/flyo2012_gben__a505284803.pdf
Aug 16, 2014 | Video Game Consoles & Games
Flymo RE320
The serial number is on the silver rating sticker on the deck, it will have the model no. and the product no.
May 26, 2013 | Garden
How do I replace the main drive belt on a Craftsman LT1000 lawn tractor?I need a schematic
No you don't, it's easy. Pull all the cotter pins out of the deck mounting brackets until the deck is laying on the ground and slide the deck out to the side. Make sure the parking brake is engaged so you have enough slack for the belt and start in back and work your way forward. You should see a little picture there somewhere on the mower of how to thread the belts through the tension pulleys. Then, put the deck back on.
Apr 24, 2010 | Craftsman Garden
Mounting a mower deck
position it under the mower then lift the rear end first and fit the link eyes through the deck mount holes. Then go to the front and lift the deck up to the link eyes, making sure the belt is on the correct side of each one. Fit the retaining clips to each link eye. Hook the tension spring through the hole at the back of the deck then go to the rear of the machine and pull the spring back and hook it onto the bracket under the axle. I use a fencing wire hook and a pair of vise grips to make this task easier. Then fit the deck belt onto the deck pulleys and finally run the belt around the motor pulley using the blades to turn it over. Refit the pulley guards and you should be in business
Apr 19, 2010 | Mtd Garden
Flymo compact350 electric grass cutter motoris
Check for debris caught under the deck. The motor may be getting ready to quit. The machine may need a replacement belt. Be careful and unplug the machine before checking.
If this is helpful, Please leave Feedback.
Thanks, SnugglePants
Oct 27, 2009 | Garden
The belt from the riding lawn mower doesn't want to stay on and we think it is the pully
usually its one of two things, alignment, or the pully itself, inspect the pully real close, the belt must fit inside the groove, somtimes these pullys collapse due to wear, the other is alignment, make sure the deck blade pulleys and the motor pulley are all at the same hieght, if there not ligned up the belt will keep flying off, also make sure you are putting the belt on right the diagram for mounting the belt is on the deck, if its not put on correctly the belt will keep flying off- hope that helps
Oct 10, 2009 | Poulan Garden
Belt replacement in a sony tc-wr645s tape deck
I have just spent half a day trying to replace the drive belts in my sony twin deck unit , in the end it still didnt work as the the old rubber belt did some damage to the unit , anyway shops like **** smith or tandy stock the drive belts , take the front of the unit away from the main case there will be a plastic casing that surrounds the belts there are at least two belts, there should only be two small screws undo these and move the plastic unit forward on the plastic mounting brackets then you will see the metal wheel and the plastic wheel that you fit the belt around , its a bit fiddly but i can do it in my sleep now even though the motor died it was a good experience
May 21, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
61 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
