Question about Hills Everyday Villa 37 Rotary Hoist Clothesline FD88010
Stripped winder or center on hills hoist
How do I replace the wire ( which has broken ) when you peg your clothes on the clothes line ?
hills used wire available from bunnings hardware or any hardware shop
May 18, 2016 | Cars & Trucks
Why will my Hills Hoist /villa 37 "free-wheel"......there is enough breeze.
Hi Bonnie,
The Hills Everyday Villa 37 has a breeze brake which is the top section of the clothesline. What this does is locks the clothesline in position to allow for ******* on windy days.
To get the clothesline to Free Wheel you need to make sure it is wound up enough to miss this breeze brake section and allow it to spin in the wind.
If you are looking for more help you can further documentation on Hills Rotary clotheslines here https://www.lifestyleclotheslines.com.au/folding-rotary-clotheslines/hills-everyday-37
For replacement parts you can also find help and advice here https://www.lifestyleclotheslines.com.au/clothesline-spare-parts
You can also find a great video on this product here to
Jan 20, 2015 | Hills Everyday Villa 37 Rotary Hoist...
How do i get the window down if the winder aint woirking
Ain't working--short of hill billy
Remove the door panel & check to see
if it has a bad switch,motor or window regulator
Non-power windows
Same thing-- but you remove the window regulator,
to see the worn out part or problem
Handle Spins-remove it & see if the serrations are stripped
Aug 12, 2014 | Cars & Trucks
How to remove hills hoist from ground socket
Wrap a chain or rope around the base, and then around a 2" x 4" length of lumber (or somesuch) near the end. Put one end of the board on the ground, and lift the other end.
Use it as a lever to pull straight up and remove it.
Jul 26, 2014 | Hills Everyday Villa 37 Rotary Hoist...
Restring hills rotary clothes line
To restring the Hills Everyday 37 rotary clothesline FD88010 you are going to need a couple of tools which include a small screw driver and a set of cutters to cut the new line cord.
You will also need to order a pack of line, which for this unit would need to be the 70m pack from Hills. Here is a link to the line pack you would need.
https://www.lifestyleclotheslines.com.au/clothesline-spare-parts/hills-70m-polycore-replacement-pack-grey-FD903530
Here is a great video on the process to restring the Hills Everyday 37 rotary clothesline FD88010
If you need to access the Everyday 37 manual you can do so here and download it.
Hills Everyday 37 Rotary Clothesline Owners Manual FD88010
Hills line clips could be something that you may also need in the restring process as these do tend to break on the older models of this unit. Below is a link to the Hills line clips that fit the Hills Everyday 37 FD88010 model.
Hills Rotary Clothesline Line Clip Pack of 6 FD902506
Jul 19, 2014 | Hills Everyday Villa 37 Rotary Hoist...
My bobbin won't catch on the bobbin winder, the metal post spins but the plastic singer style bobbin won't spin with it. What's wrong?
The bobbin may be stripped, or the bobbin winder might be stripped; try it with a different bobbin, to rule out the bobbin being the issue; if that doesn't work, look closely at the bobbin winder to see if it has been damaged. You may be able to adjust it's shape with a pliers
Apr 02, 2012 | Singer 3116 Simple
How to restring hills hoist
I'm just doing mine right now. What follows refers to the earlier folding hoist model Rotary 42, not the fixed wire line models, or the current Hills folding hoists with this type line anchor
http://www.breezedryer.com/index.php?p=product&id=791
I found that Hills don't sell new line direct, so I got some poly core line from Mitre 10, 60m for $30.
Study how the original line was strung through the clips and how it was tied at each end, and you will find that you have to remove 4 plastic wedges which secure the line in the end caps, these things
http://www.breezedryer.com/index.php?p=product&id=792
The wedge is not shown. You just push it out upwards. Then cut away and pull out the old line from all the clips, these things
http://www.breezedryer.com/index.php?p=product&id=741
Then tie the line onto one end cap as it was before, and restring the whole hoist. To get the line into the clips, you can carefully lever a bit with a screwdriver.
Don't worry too much about tension yet, just leave the line a bit slack on each run. You will have to pass the coil of line over the top of the arms many times. Finally cut it off after the final run, leaving enough line hanging down to secure the arms in a bunch when the hoist is folded up.
Make the final knot as it was, and then, without skewing the arms sideways, remove any slack going around and outwards, and finally pull in and tighten the final knot at the outer end, and replace the 4 wedges.
The line will stretch, so you may need this final step once more.
Sep 11, 2011 | Husqvarna 28cc Gas Line Trimmer
Hills Everyday Villa 37 Rotary Hoist Clothesline FD88010 Logo
116 people viewed this question
Top Hills Home Experts
Donni Steen
Tom Chichester
Are you a Hills Home Expert? Answer questions, earn points and help others
