Question about Garden
Fuel line diagram for wt 628 carburetor - Garden
4 Suggested Answers
SOURCE: I need the fuel line diagram for a Walbro carb. Wt 231 k1
need to know which feul and which is return
Posted on Jul 16, 2009
panilling9
  • 284 Answers
SOURCE: Which fuel line "port/inlet" on the Walbro wt-380
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Posted on Jun 25, 2010
rycgl
  • 1545 Answers
SOURCE: Do you have a diagram that shows where all the
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on Oct 24, 2010
Carburetor diagrams
I know of no diagram available for this. But if you have both lines out and visible you can just put them on the carb, fill the tank and prime it and see if fuel moves. If it does your done....if not....flip the lines and try again!
Jul 16, 2014 | Poulan Mvm200vs, Ppb430vs Vs2000bv Blower...
Walbro wt-141 changeover to wt-629
If the carb has two connections then it is designed to work with a primer bulb, the fuel inlet will be nearest to the pump cover, the alluminium cover held with a single central screw, you can either get the correct carb for the machine or use a short rubber tube with a blank in the end ti close it off.
Feb 02, 2013 | Poulan Weedeater Carburetor - Walbro...
Ryobi cultivator #RY60511A : Need diagram or text to show the fuel lines from the tank to the primer and the carburetor.
here is a manual,Tim:
http://lawnandgarden.manualsonline.com/mdownloads/38dcb043-331f-461b-a08c-072d67fc76c0.pdf
here is a diagram:
http://photos.hobbytalk.com/showphoto.php/photo/34693
in a nutshell:
1 connect top carburetor line to short nipple on primer bulb.
2 bottom carburetor line to fuel line with filter (inside tank).
3 connect remaining fuel line that comes out of fuel tank to the large nipple on primer bulb.
Hopes this helped Tim
May 29, 2011 | Garden
Its a 1985 Yamaha xj700 maxim that has a problem with the fuel and vacuum line, from the fuel tank to carburetors and drain line diagrams
Hi, Sevensons7 always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Fuel valve/petcock not in the on or reserve position.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing*
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn*
7. Fuel line from the fuel valve to the carburetor or fuel pump clogged, cracked, pinched, bent, broken, or missing.
8. Fuel pump not working*
9. Fuel line touching cylinder or head causing fuel to boil and vapor lock, repair by rerouting and wrapping line with convoluted tubing.
10. Carburetor inlet clogged.
11. Carburetor float or needle and seat stuck.
12. Carburetor not venting properly overflow line or bowl fitting clogged, pinched, or bent.
* If equipped or applicable.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Yamaha XJ 700 Fuel and vacuum line diagram Google Search
petcock fuel yamaha maxim xj700
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Apr 02, 2011 | 1985 Yamaha XJ 700 X Maxim
Replacing fuel line on trimmer model 775r - have have removed all the fuel lines and the bubble, but have forgotten the exact pattern to replacing the three fuel lines
Hi: I'm a new user to this forum. I recently had to repalse the 3 fuel lines on my ryobi model #775r. After researching the problem, I diagramed the flow of fuel in order to repace the fuel lines. If you require a copy of this diagram, send me an email . Regards, Tony
Oct 07, 2010 | Ryobi Garden
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
How to replace the Husqvarna chainsaw fuel line.
let me knoe the model number and i'll see what i have....
Oct 29, 2008 | Garden
Garden Logo
673 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
