Question about Grundfos MQ3-35 3/4 HP Pressure Booster Pump
Pump keeps blowing house fuse - Grundfos MQ3-35 3/4 HP Pressure Booster Pump
It is likely that the shaft seal in the pump has failed and the water is leaking into the motor. Water and electrics = fuse blowing!!
Posted on May 16, 2014
Fisher and paykel keeps blowing fuses, code 37, I have replaced the pump already
Yes the original bad pump has damaged the drain pump circuit on the control board.
Dec 20, 2016 | Fisher and Paykel Washing Machines
Why i keep blowing a fuel pump fuse?
Hey Paula, if it keeps blowing that could mean a short in system or more so the pump is having trouble pumping it is 20 years old also check the fuel pump relay
Oct 17, 2014 | Cars & Trucks
Fuel pump fuse keeps blowing (new pump too)
The replacement fuel pump could be defective.
Mar 31, 2014 | 2001 Ford F250 Super Duty Super Cab
Fuel pump fuse keeps blowing on my 95 Crown Vic
Using a smaller fuse should make the problem happen more often.
A mechanic would unplug the pump harness at the tank and check the circuit for high resistance or a short to ground.
If nothing is found in the harness, I would suspect the pump in the tank.
Jul 19, 2012 | Ford Crown Victoria Cars & Trucks
Fuse for fuel pump keeps blowing
Normally fuse blows off if more current passes through it than what it is designed for.
Probably it is worth checking what original fuel pump fuse amps requirements and have the same installed.
Also check the relay if there is a relay set for the fuel pump.
Good luck
Jul 13, 2012 | 1992 Toyota Previa
95 chevy blazer keep blowing the ecm fuse
If it "keeps" blowing the ECM fuse, it is because you "KEEP" replacing the fuse without diagnosing and repairing the reason the fuse is blown.
Please review these articles:
Where's The Fuse?
What Else Could Be Wrong?
What To Expect From An Online Car Expert
Jun 04, 2011 | 1995 Chevrolet Blazer
Fuel pump fuse keeps blowing?The fuse is by the right front of radiator.
FUEL PUMP WIRES HAS A SHORT OR FUEL PUMP BAD SHORTING OUT.BLOWING FUSE.CHECK FOR SHORT AT FUSE BOX AND AT THE FUEL PUMP WIRES.THE PCM GOES BAD SOMETIMES IT WILL SHORT OUT BLOW FUSE TO FUEL PUMP.
Apr 14, 2010 | 1992 Oldsmobile Cutlass Ciera
Fuse keeps blowing for fuel pump
The fuel pump is most likely "going bad" -- the motor winding is begining to short and pulling too much current.
Charlie
Sep 28, 2009 | 1996 Volvo 850
1993 ford explorer fuel pump fuse keeps blowing
Josh. The best and safest way to find a short is to find it. But, the fuse wonwon't give yo time. So, Let's create time and replace the fuse with an aitomatic fuse/circuit breaker. It will cycle automaticly until you locat the problem. When yo locate the short it will quit cycling.. Just put it in place of the original fuse and listen. Do not exceed the original fuse capcity. they are available at autoparts stores. good luck and if this helps, fill our the questions fixya asks. please
Dec 21, 2008 | 1993 Ford Explorer Limited
Grundfos MQ3-35  3/4 HP Pressure Booster Pump  Logo
153 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
