Question about Frigidaire Washing Machines
Frigidaire affinity washer ATFB6700FS0 -- after setting cycle and pushing start button,the door locks but then each light turns off, the door unlocks and the washer turns off with no error code.
IFIXALL
  • 868 Answers
SOURCE: Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
esbee0522
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
erickg
  • 116 Answers
SOURCE: The washer door wont shut or lock on my frigidaire affinity
in the rubber seal around door to washer tub ensure there is nothing inbetween rubber.
Posted on Apr 21, 2009
dblred
  • 68 Answers
SOURCE: my Frigidaire affinity washer doesn't
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Posted on May 06, 2009
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I have a frigidaire affinity front load washer that will not lock and start. I turn the dial, all pertinent lights come on, but no door lock and it alternates between cycle time and "Pau" which...
is there any water in the drum if no then it could be your door catch try shuting the door with a bit more force or pushing on the door when you turn on the machine if it does not start then it will be that you will have to replace your door catch
Oct 15, 2011 | Frigidaire Affinity ATF7000E Front Load...
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity front load washer doesn't start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Dec 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity washer doesn't start
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
Frigidaire Affinity ATF7000E Front Load Washer WAS working, but now, it won't work. IThe settings appear to work, since all the lights light up for the various setting. I then press "Start" and the the...
The control is most likely bad. If lights flash on front let me know which ones and how many as it will sometimes tell me what the failure is. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Fridgidare Affinity washer door won't open after wash cycle
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Sep 14, 2008 | Frigidaire Affinity ATF7000ES Front Load...
New frigidaire washer (affinity)
Kimberely, The err 47 means that the control board is not sensing the door lock. First try unplugging the machine for 1 minute and see if it comes back to normal. If it doesn't put it into the door lock test, with the door closed, by doing the following: Turn the program knob to drain spin. Press pause cancel to turn off the LEDs. Within 5 seconds, press and hold the option and pause cancel buttons until the LEDs start sequentially chasing, then release the buttons. All the LEDs will sequentially light. Turn the program knob 4 clicks from the start position clockwise, the door lock solenoid will activate. The door should be locked. Turn the knob one more click clockwise and it should unlock. You can toggle back and forth to test it. If the door lock is working and you are still getting this code, then its a control board problem. You should call for factory service. If you have any more questions, you can email me at catriver1@gmail.com Catriver...post back.
Jan 20, 2007 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
