Question about Midland Audio Players & Recorders
What type of microphone is a midland 22-150, dynamic or condenser? Does it require a 48V dummy load?
  • 73 Answers
Its dynamic and no it doesn't need phantom power
Posted on Apr 23, 2009
Microphone recommendation for KLM-2700
Just about any mic will do. I have used a Midland, Motorola, GE, Radio Shack and other microphones on these radio's. The mic element must be dynamic. Condenser microphones would require you to slightly modify the mic input circuit of the KLM to provide 5 to 10VDC through a 4K7 resistor to provide bias for the condenser element. It's easy to do if you have the skills to do it.
Jan 30, 2014 | Cobra Hand Microphone Wired For Klm Multi...
C451eb dead?
hard to say without more info. you probably know this , but as a condenser mic it requires 48v phantom power to operate. Does the pre-amp/mixer you are plugging it into provide that (there will be a button on it marked 48v)? If not, that is the problem.
Apr 30, 2011 | AKG C451B Professional Microphone
Hi, my M-audio Project mix stop to send 48V phantom power, Do you know if had a fuse protector inside? Tks Wallace
A common problem is a person will plug in an unbalanced plug into an input. this often grounds out the 48 volts. Use ONLY balanced lines like XLR and TRS connections. There is NOT likely a fuse inside as the 48 volts have fairly high impedance driving the mic leads... around 6K ohms. Verify that the 48 volt control setting has not been turned off.
Apr 23, 2011 | M-Audio 99104074200 ProjectMix I/O...
I have dropped the mic onto a hard floor and now it will not work. How can I take it apart?
Depending on the type of element; dynamic or condenser, you won't likely be able to repair this yourself. Both are delicate and use very small dimensions. The condenser type are most likely to survive a drop but the dynamic type is easier to damage and if it is an E815S, it's dynamic.
Feb 27, 2011 | Sennheiser E815S Professional Microphone
Im doing some audio recording on my lexicon omega soundcard and i recently bought a microphone sennheiser e835s and i was wondering if this microphone can operate using phantom power?
Phantom Power (or an internal battery) is needed to operate 'Condenser' type microphones.
The E835S from Sennheiser is a 'dynamic' microphone and, as such, does not require any power source for it to operate.
If you are using several different types of microphone together (dynamic and condenser) it should be quite safe to have phantom power on - it won't cause any damage to the Sennheiser.
However 'ribbon' microphones will be destroyed by phantom power
Feb 10, 2011 | Sennheiser E835S Professional Microphone
I just bought an audio technica at2020 cardioid condenser mic its the 20 series and i cant figure out how to get it to work on my toshiba laptop
Unlike 'Dynamic' microphones all condenser microphones require some sort of power supply to make them work. Sometimes this can be by way of an internal battery but many of them work on an external 'phantom' power supply.
I am not familiar with the exact model number you quote but AT make 2 types of AT2020 condenser microphone.
1) If your AT microphone is fitted with a USB plug then you can connect it directly to the USB socket on your computer, which will provide it with the power that it needs to make it work. The USB bus should automatically recognise the microphone and allocate an audio channel to it but you may still have to select this device as your input source in your recording program. How you do this will differ from one program to another.
2) However if the microphone is fitted with a standard jack-plug then it will not work by you just plugging it into your computer microphone input socket as this is not powered. You will need a separate 48volt DC power supply to power the microphone.
You will almost certainly also need some sort of microphone pre-amplifier to match the output voltage and impedance (electrical resistance) of the microphone to the levels required by your audio input socket on your computer.
Probably the best way to achieve both of these requirements at lowest cost would be to purchase a small audio mixer with a phantom power option such as the Phonic AM220 http://cpc.farnell.com/phonic/am220/mixing-console-am220/dp/DP29303
WARNING - most audio mixers only have one on/off switch for phantom, power - thus the power is either on or off for ALL channels. Some other devices - like radio microphones, keyboards and electric guitars may be damaged by having 48v dc current supplied to them
Here is a link to the technical specs sheet for the AT2020 http://www.audio-technica.com/cms/resource_library/literature/49f63e6efc082082/at2020_english.pdf
More information is available here http://www.dolphinmusic.co.uk/article/40-why-do-i-need-a-microphone-preamp-.html
Jan 28, 2011 | Audio Technica Audio-Technica AT2020 -...
Microphone is brand new but won't work on the computer...
Be sure to use phantom power (48V), as this microphone (condenser type) requires it for use. Hope this helps.
Apr 25, 2010 | Blue Microphones Baby Bottle Professional...
I cant make my condenser mic to work with mixcraft only dynamic w
Condenser microphones need phantom power (48V) to operate. Some condenser mics use batteries to work and get around using phantom power from an audio mixer. hope this helps
Feb 28, 2010 | Samson C01U USB Condenser Microphone...
Where can I find a Midland 22-211 dynamic wiring diagram?
http://i79.photobucket.com/albums/j149/johncheney/todd/IMG_0057.jpg
Original Diagram that came in the box with this microphone!
Jan 04, 2010 | Midland Audio Players & Recorders
77 people viewed this question
Top Midland Audio Players & Recorders Experts
John
John
Are you a Midland Audio Player and Recorder Expert? Answer questions, earn points and help others
