Question about Dell Vostro 2520 Laptop Computer- Intel Core i3-2328M 2.2GHz
Dell mouse cursor moves accross screen
Why has my umping around and how do i stop it? Disconnected the internal mouse but still having problems. jl mouse startedogitech
SOURCE: Mouse cursor moving by itself
I have the same dell computer, you have to down load the newest synaptics driver and disable the touch point mouse in the middle of the keyboard.
Here is the link.
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&qmp=12&p=1&subcat=dyd%2f17&rf=all&nk=t&sort=-date&snpsd=A&ira=False&spf=Latitude&ssysid=LAT_PNT_P3C_C610&ssysn=C510+%2f+C610&~srd=False&ipsys=False&advsrch=False&~ck=anav
Hope this helps!
It worked for me.
Posted on Feb 09, 2008
coldsilver20
  • 113 Answers
SOURCE: Dell Cursor Typing Blinking Problem
this is because you must deactivate your touchpad. you can do this by holding the Fn key and pressing the F* key that shows a picture of a touchpad in the same color as the Fn.
or you can go to control panel and turn it off in the mouse settings. but just attaching a mouse will allow the touchpad to stay active and therefore still be sensitive enough for your hand to "tap" th cursor.;
Good luck and pls rank this response! :D
Posted on Mar 16, 2009
ta_mcguire
  • 125 Answers
SOURCE: Dell D620 cursor not working- floating all over
you will need to reload the drivers with dell laptops there is a order in which you have to install the drivers it is shown on the right side of the drivers download page
Posted on Aug 02, 2009
anandsharad
  • 137 Answers
SOURCE: how can I stop cursor from moving to new location
Does this happen when the adapter is connected or not.. most of the time is an adapter problem. try checking it on the battery and on the adapter. If you find change in the erratic moment on the battery. its an adapter problem.
To reinstall the touch pad driver for your machine. click on the following link.
For windows vista:- http://tinyurl.com/ntq4a3
For windows Xp: - CLICK HERE
Again, i would strongly advise you to change the adapter and use the computer. ;)
All the best
Posted on Sep 22, 2009
  • 43 Answers
SOURCE: drifting mouse pointer
Go to Control Panel - Mouse - Pointer Options - and uncheck 'Enhance pointer precision'.
Posted on Feb 28, 2010
Mouse stopped working - cursor won't react
What type of mouse do you have, the brand and the model. Sounds like you need a driver for the mouse you have. If im understanding right you have a wireless mouse?
Jan 11, 2010 | Computers & Internet
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
Dell Lattiude D600 cursor locked in middle of screen - even after we turn on and off - no way to do anything because cursor won't move - not even little blue mouse in the middle of the screen
Try booting up after installing an external USB mouse. This may give you a mouse to install new keyboard drivers.
If the problem is the keyboard/tracking pad, (hardware) installing another keyboard may eliminate the issue.
Jun 14, 2009 | Dell Latitude D600 Notebook
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
Cursor jumps around
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
Aug 14, 2008 | Computers & Internet
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
i have latitude c610 and same problem happens with me too. i think that happens when i finish my brakfat and without cleaning my hands start using the touch pad. what happens according to me is that small particles of food(eg bread/dust particles) stuck in the corners or the body wall where the touch pad ends and keeps pressing the touchpad, thus causing the mouse to move to one direction. when i clean the corners and sides of the touchpad, it starts working ok !!
thanks
Johal
Dec 12, 2007 | Dell Latitude C610 Notebook
Dell Vostro 2520 Laptop Computer- Intel Core i3-2328M 2.2GHz Logo
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
