Question about Kenmore 62972 Electric Dryer
I have a Kenmore Gas Dryer with Model # 11074842400. I need to know how to remove and replace the moisture sensor. Please help?
  • 110 Answers
SOURCE: kenmore gas dryer model # 87566100
BAD SOLENIODS OR THERMAL SAFETY
Posted on May 30, 2008
  • 161 Answers
SOURCE: Directions to replace gas valve - Kenmore dryer model 41790042990
If you have a 2 piece front panel just pry the bottom part open from the top, right under the door. It will swing down and lay flat. You can remove the gas valve assembly now. It is on the left. If you have a one piece front. remove the lint filter and then the two screws there. Be VERY careful not to drop anything down the hole. (It will ruin the fan.) Pry the top off by using a butter knife or thin screw driver to push in the clips in the front corners. It will swing open from the front. remove the wires from the door switch. Use a 5/16 socket to remove the screws holding the front panel in place. Pull out and up the bottom is held by clips. Be careful not to let the drum fall all the way out. When you reassemble the dryer before you put the top down , turn the drum a full turn to make sure that the felt seal at the back is seated properly.
Posted on Jun 29, 2008
canbruce75
  • 1776 Answers
SOURCE: Kenmore Dryer model 110.62932100
First, make sure that there is no ventilation issue and that the vent is clean and clear. If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Remember to disconnect the dryer from the power source before attempting any repair.Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 29, 2009
SOURCE: coil replacement
I'm not an expert but assuming you ordered the coils for your dryer your dryer must have them. I just finshed repairing my kenmore gas dryer after about 10 minutes the gas would shut off. This is becasue the coils that are on top of the gas line before the ignigter were defective. The coils control the gas valve and when my dryer got hot the coil being defective would close the valve. There are 2 coils a 2 prong and a 3 prong. Remove the front panel to gain access to the bottom of the dryer from there you will see your coils about as round as a quarter and 10 or so high. unscrew the screws holding down the retainer and undue the electrical clip. reverse for the install. good luck!
Posted on Dec 17, 2009
  • 572 Answers
SOURCE: Kenmore gas dryer - Running dryer while empty and
ur vent might be clean but also make sure its not long enough that makes ur dryer hard to get the heat out fast enough
Posted on Feb 09, 2010
Dryer will not shut off. set on more dry
The problem is likely the moisture sensor has failed. They are inexpensive and easy to replace. Here is a link that should help Moisture sensor replacement
Oct 21, 2010 | Kenmore 73952 Gas Dryer
My kenmore dryer series 70 is not heating, i replaced igniter, thermo sensor, and still does not heat....there is no glow from inside please help....
Check the fuse Note: Gas dryer thermofuse is linked to the gas assembly and blows whenever the temp exceeds 350f rapidly. Remove all air restrictions15f9d55.jpgbefore replacing that fuse or you will just need to keep buying em.f8e11bb.jpg65c991e.jpg
May 08, 2010 | Kenmore 62602 Electric Dryer
Kenmore gas dryer 80 series model 11074842400 takes twice as long for it to dry and vent is clean and clear
Go outside and see if you have lots of air coming out. If it is just a little then you have an obstruction somewhere in the vent or the drum or door seal could be bad allowing air to escape inside the house. Your blower wheel could be broken. There could also be something inside the machine blocking air from getting in.
I hope this helps, Let me know if I can help with anything else.
Mar 20, 2010 | Kenmore Dryers
Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
Mar 27, 2009 | Amana DLG330RAW Gas Dryer
Kenmore Gas Extra Capacity heats only on timer,not Fabric Master.
get some windex and clean the sensor strip located behind the filter ousing similar to this picture. Their might be something on it that is interfering with its moisture sensing ability. Check out my youtube channel about section for a link to a free dervice manual for you model. Thanks
Dan Webster
Jun 18, 2017 | Kenmore 73952 Gas Dryer
HE4 Kenmore Elite Dryer error code 4e
If you have ever removed the lint filter area completely via the screws that hold the plastics in so you could clean it then remove it again and insure that you plugged in the two wires that go to the strip sensor.. (moisture sensor)
May 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 62972 Electric Dryer Logo
26 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
