Question about Rangemaster Kitchen Hood
106 2s replacement filter part #6124-02 where to buy or dimensions to replace with another.
How do I buy a filter for my duraflame #10HM4126POA?
It's no longer being sold. If your owners manual has no contact info for parts, just Google your brand and model. If that fails, measure your filter dimensions and buy a generic filter sheet at a hardware store. I have a similar model and I don't see why a 3M fiber pad wouldn't work. Just remove it periodically, wash it out, dry it, and reinsert.
Dec 26, 2014 | Heating & Cooling
What filter do I need for my Ducane furnace?20x25x5 furnace filter compartment
Filters are sized according to their dimensions. Using those dimensions, buy whatever filter that suits you.
Sep 03, 2013 | Heating & Cooling
Previous fan failure
? I'm not sure what your question is, but replacing the fan on a dell dimension is pretty easy.
Here are the instructions: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/parts.htm#1139391
And heres a link to buy one off of amazon: http://www.amazon.com/Dell-K0456-Assembly-Dimension-OptiPlex/dp/B000MME1TW
Dec 30, 2011 | Dell Dimension 4600 PC Desktop
The unit freezes and does not cool until thawed
This sounds like one or all of these issues:
1. It could be due to lack of good airflow from the cooling coil because your air filter needs to be replaced.
2. You could just have an old compressor that needs to be replaced.
3. You could have a refigerant (freon) leak in your system, causing it to freeze.
The first issue can be fixed by yourself, when you replace your air filter, make sure you take note of the dimensions of the filter so you can buy the correct size. There will be an indicator as to which direction the filter should be facing on the side of the filter itself after you purchase it from your local home improvement store. If you replace your filter and the problem persists, you should call a liscenced professional to come out and assess the issue since the chemicals from the replacement of the compressor and fixing the refigerant leak can be harmful.
Aug 18, 2011 | Goodman CKL60AR60 Air Conditioner
I need to buy replacement internal cd-rom for my Dell Dimension 8110
Any IDE CD-ROM Drive will do just fine... Just make sure you configure the jumpers according to your specific setup (look at the old drives jumpers if you don't know).
Dec 05, 2010 | Dell Dimension 3100 PC Desktop
Need to replace fuel lines on my Troy Bilt gas hedge trimmer. Where can I get replacement fuel lines... or better yet... what size are the lines and where can I buy a few feet of the lines. Note: I...
Replacement fuel lines should be readily available at your local lawnmower repair shop. Your TroyBilt hedger uses fuel line that is 3/32" (2.4mm) interior dimension, 3/16" (4.8mm) outside dimension, with a 3/64" (1.2mm) wall dimension.
Most manufacturers don't offer replacement line, only fuel tank assemblies. Find your local shop, and try to get the TYGON brand...it is yellow. Tygon lasts the longest. You should be able to buy it by the foot for less than $2 per foot. You will need 2 feet of hose to replace both lines.
Make sure to clean the in-tank filter when replacing hoses.
Good luck.
Oct 20, 2010 | Craftsman 22" Gas Hedge Trimmer
Where can I purchase a power unit for a Dell Dimension XPS T450?
When you say power unit, I imagine you mean the power supply. They can be purchased in different places, such as Best Buy, or probably anywhere a computer is sold. Microcenter is a good store if you have one near you.
The place where I get my PSU (power supply unit) is a website called http://www.newegg.com, which usually has quite nice deals on things, and you can filter through products in a nice efficient way.
If you'd like to know more about purchasing power supplies in general, I'm providing a step by step guide which you can find here.
Hope this helps :)
Dec 02, 2009 | Foxconn 6100K8MA-RS Motherboard
Where do I get filters for my Airwell Airconditioner?
take down the dimensions of the air filter. like 16" wide x 20" long x 1" thick. the go to your local hardware store. or lowes, home depot hope this helps.
Jun 13, 2009 | Heating & Cooling
Carrier A/C Filter
is it horizontal or vertical 2 different sizes
May 26, 2009 | Heating & Cooling
Rangemaster Kitchen Hood Logo
23 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
