Question about Swisher Zt2560 Zero Turn Radius 60" Riding Mower
Teansmission oil for transmission
Teansmission oil for transmission oil zt20056
What is the type of engine and Automaic transmission oil shall I use in lancer 2002 1300cc motor 4g13?
15w-30 engine oil and ATF transmission oil probably an atf -4 oil
ring any automatic transmission shop for the oil specs
make sure that it is a genuine automatic transmission and not a cv transmission ( constant velocity )transmission as using ATF oil will destroy the belt and the transmission
Oct 17, 2017 | 2002 Mitsubishi Lancer
How do you check the transmission fluid
there is really only one way to "check" your trans fluid. it involves getting under the car, loosening a bolt on the trans and adding fluid until it starts to pour out. gm attempted, poorly in my opinion, to use the closed fluid system therefore there is no dipstick. the teansmission fill is located on the drivers side under the throttle body. it is a red screw in cap. you will have to remove the breather box to access it easily
Dec 25, 2011 | 1998 Chevrolet Malibu
Buick Century 2001: the Service Engine Soon warning light came on and was diagnosed as code P0740 Torque Converter Clutch Circuit Open. The transmission fliud has been replaced and the Engine Service...
change your fluid and filter in teansmission WARNING :start car and shut it off just before you do because if you dont you will burn the bands up.I recommend Lucas transmittion conditioner as well.My grand prix calls for sythetic 2003 7 quarts so check with salesman and see what kind it calls for and also count the bolts and pattern before you buy so you make sure you have the right one before you start your project.
Jun 11, 2011 | 2001 Buick Century
What's the difference between a tranny with o/d and one without o/d, 02 neon xst?
od stands for over drive. a stander finel drive with out od . is one to one that means for every turn of the engine or input shaft of the teansmission .the output shaft turns at the same rate its called 1 to 1. on a over drive the out put shaft turns faster than the input shaft. you may see a turn rate like .75 to 1. that means the engine has turned 3/4 of the full turn .but the transmission output shaft has made a full turn.
May 06, 2011 | 2002 Dodge Neon
The engine revs but the car will not reverse or accelerate
SOUNDS LIKE A TEANSMISSION PROBLEM ..WHEN YOU ENGAGE IT IN GEAR DO THE RPM'S FLUCTUATE AT ALL..OR DOES THE CAR ****..?
Dec 25, 2010 | 1992 Mitsubishi Diamante
Slight grinding noise in 3rd gear pops out now wont engage ANY gear clutch feels normal shifter feels normal , 190,000 miles was about to need cluch still the original
your teansmission is going to be overhauled. it sounds like the synchros are going bad. the shifter has forks that move the gears. sometimes the forks wear out and it can cause the gears to wear out because the gears are not going into like they are suppose to. leave comment..
Mar 29, 2010 | 2003 Ford Ranger Regular Cab
I want to puchase a ford escape 02 i just wanna know if its good car, i live in brooklyn new york
Do NOT purchase this vehicle. Do a search and you will find the teansmissions are BAD! Mine just went and I see it's commen problem and Ford is of no help if your warranty has expired, as it would have by now.
Mar 01, 2010 | 2002 Ford Escape
1996 Ford Taurus transmission "dumps " fuild
There are no guarantees when it comes to a rebuilt transmission or anything. They usually have a warranty for the work all depending on the mileage afterwards. Is it over it? Most likely the gaskets need replacing and the bolts tightened again.
Sep 13, 2008 | 1996 Ford Taurus
Swisher Zt2560 Zero Turn Radius 60" Riding Mower Logo
Top Swisher Garden Experts
Tim Whalen
dannydoesita
ray gallant
Are you a Swisher Garden Expert? Answer questions, earn points and help others
