Question about Thermaltake Symphony mini Water Cooling Kit
Symphony Mini tower dissassembly ( or how to unscrew the pumps?)
I have to replace one of the Symphony Mini water pump but I don't know how to disassemble the tower.
No way to register to thermaltake forums, I found one post exactly describing my problem though:
http://forum.thermaltake.com/viewtopic.php?p=7922&sid=42b1e97c7dc08fd74a20fd8922f0c168
I tried disassembling the system to reach to the dead pump so that I can pull it out and replace it with a new pump .
Half way through there was absolutely no way to unscrew the pumps. I unscrewed the base of the system and reached the area where pumps are loacted. The problem is that both pumps are screwed to the body of the system wich is a big cast of Alu. There are screws there but no way to reach them at all unless I cut the body of the Symphony where the pumps are located.
Any tips on how to dismantle the pumps off the Symphony Cooling kit are highly appreciated.
  • 2 more comments
  • BillyJoe3030 Apr 23, 2009
    Here is a pdf explaining the steps.
    I'm stopped at phase 4) I see no way of pulling those inner side panels / rail out.
    I mean I see there is a kind of rail , but pulling hard on it has no effect like it was screwed to the top of the case.
    I suppose I would have to dismantle the grill to access the top, but the grill is firmly fixed and this is nowhere described in documentation. Another view of the whole thing.
    (And I see no screws that may be accessible with an offset screwdriver).
  • David Shaub May 11, 2010
    Have you tried using an offset screwdriver? Many units are assembled using right angled drivers at the factory, not being concerned with repairs.
2 Suggested Answers
  • 45 Answers
SOURCE: Water cooling noise
Could be air in the system which you would need to bleed out. Either that or a faulty pump.
Posted on Sep 29, 2008
Wash cycle is OK but on the rinse cycle the water only dribbles out, This happens on ALL programs?
Hello there and welcome to fixya
This is a fairly common problem with washing machines, All washing machines have a drain pump that pumps out the water in the drum from the machine to the main drain that your hose connects to.
So what you need to do is to remove the pump and clean it out depends on the make and model of the machine there may be a bout 4 screws that hold on the pump cover or may just be a clip or 2 but once removed you can see the trash that is inside of it you will be amazed on how much change and odd things you will find in there ok? i will post some pictures of these pumps with dissassembly instructions it is really not that hard ok?
26028797-bgdijlkweudpur0wk3rytzfu-2-2.jpgthis one simply u unscrew the white piece and clean out
Dec 30, 2015 | Washing Machines
How do you fix a water pump on a 1988 nissan z24 mini truck
you don`t fix you replace the water pump to stop the leak.
Oct 05, 2014 | Cars & Trucks
Water pump question
this impeller is attached to a pump that will pump out the water out of the machine.
There fore it should have resistance all the time If not then it may need to be replaced meaning the impeller but if it is removed and is in good working order then the pump has failed and will have to be replaced ok
Please post back if you have any other issues or need instructions on how to remove the pump for dissassembly and repairs
Best regards michael
Apr 25, 2013 | Frigidaire Gallery GLWS1339EC Top Load...
How do i replace the water pump....3.3 L
first find the water pump for every vehicle ive ever worked on the water pump is always right above the main pulley once you locate the pump unscrew the hose from the pump to the radiator and then take all the bolts off the pump slowly wiggle the pump off so you don't damage the gasket on the water pump then take your new water pump and line it up to the holes for the bolt and put all the bolts back in and then reattach the water pump hose to the pump and to the radiator and then fill the radiator up and your good to go
May 07, 2012 | 1991 Dodge Dynasty
Noisy water pump from my mini is this a common fault
I have answered lots of Mini questions and this is the 1st one about the water pump being noisy. The problem is caused by the pumps shaft bearing seal leaking, this destroys the shaft bearing. Don't let it go so long that the shaft breaks, and it will.
Jan 23, 2012 | 2004 Mini One
I have a Maytag Epic frontloader that is flashing F-21. The manual says to much suds. I use HE detergent already, but I know that I used to much by accident this last time. I need to see where the...
Hello Lisa,
The screws are going to be on the underside of the lower panel their is 3 of them,they are in the corners and 1 in the center...i believe they are 9/32" size but also T10 torx headed.
To check the drain pump their is no need to remove the pump just unscrew the big white cap and pull it out..thier is always water in the tub so at first unscrew it just a little and have a couple towels to catch the water,when all the water is out unscrew completly and it pulls out
GENE
Sep 17, 2011 | Maytag EPIC MFW9700S Front Load Washer
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
Water cooling noise
Sep 24, 2008 | Thermaltake Symphony mini Water Cooling...
Thermaltake Symphony Mini water cooler making annoying rattling sounds!
Check the screws of the fan if it is seated properly. Then check your system unit if it is leveled on the ground. Or it could be dust or rust. You can try oiling up the fan.Open up the sticker of the fan and put little oil in it and put back the sticker. You may need to put extra tape as the oil may hinder the sticker from sticking back to the fan.
Sep 16, 2008 | Computers & Internet
Well pump
i bougth mini jet star popcorn machine in a garage sale but without instructions and i don´t know how to make the popcorn
Jun 22, 2008 | Kitchen Appliances - Others
Thermaltake Symphony mini Water Cooling Kit Logo
224 people viewed this question
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
