Question about Garden
How to replace a pull cord on a sears lawn mower 7137034
  • 45 Answers
SOURCE: Lawnmower Starting Pull Cord Replaement
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Posted on Sep 27, 2008
evwood
  • 50 Answers
SOURCE: replacing pull cord on troy built mower model # 8654r 4hp
Remove the housing covering the clutch. The cord spool can then be accessed. Replace the cord. Be careful that you maintain the proper spool spring tension. Check operation before reassembling
Posted on Feb 06, 2009
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
  • 109 Answers
SOURCE: Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Posted on Apr 26, 2009
  • 1111 Answers
SOURCE: I have a briggs and stratton lawn mower ad the pull-cord is stuck
make sure nothing is jammed around the blades...if thats ok, remove the pull cord housing and try and spin the engine. if it doesnt turn, the motor is locked up and needs repaired
Posted on Jul 10, 2009
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
Pull cord stuck on lawn mower
Pull cord stuck on lawn mower YouTube
https://www.youtube.com/results?search_query=Pull+cord+stuck+on+lawn+mower
Sep 06, 2014 | Toro Garden
Pull cord hard to pull and won't reel back in
should never pull cord unless correct amount of oil is in it !, My advise take back to sears and buy a Toro ! Did you have the blade break lever pulled back ?
Oct 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Pull rope on sears 5.0 lawn mower pulls hard sometimes or you pull the cord and the spindle does not always turn. I guess it's not catching all the time. What can I do for it ?
If mower has sit outside for a while the works in the recoil may be rusty and dry. Try some oil in all the working parts. See if that works for you.
Aug 02, 2012 | Sears Garden
Lawnmore pull cord replacement
Sears technicians can repair Briggs and Stratton cords fairly easily and it won't cost you much either. I had mine serviced last year and it took about 3 weeks and they just sent it off to the technicians and I just had to pay around $50 total.
Jul 07, 2012 | Briggs & Stratton Garden
Pull cord broke of mower starter
Go buy part at Home Depot or wherever. Remove top cover. Remove pull cord housing. Install new pull cord housing. Replace cover.
Oct 09, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
It won't start. The pull chord won't pull out. Even a little. It was out at one time, in the loop on the mower handle, but I had to let it go into the motor and now it won't come out.
You will probably have to disassemble the rewind assembly and either replace the rope and/or straighten out the cord and properly reconnect it to the flywheel connection. Kits usually are available at the Sears parts store or lawn and garden centers that handle lawn mowers everywhere.
Best wishes,
TF
Jun 03, 2011 | Garden
Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
May 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Pull cord on Sears 4.5 mower binds up
check, or have someone check the flywheel key, it is probably sheared off.
Apr 20, 2009 | Craftsman Garden
RE: SEARS SELF PROPELLED LAWN MOWER 917.374750..WHEN PULLING THE CORD TO START THE MOWER ( AS USUALLY IS DONE ) THE CORD FAILS TO MOVE. CKED THE UNDERSIDE FOR POSSIBLE OBSTRUCTIONS & FOUND NONE.
Most lawnmowers manufactured over the past 15 years have a safety lever that needs to be pulled in to allow the mower to be started. This lever is normally located near the handrail and acts as a failsafe that shuts down the mower if you were to trip or release it . The intent is to protect you from injury if you let go of the handlebar. make sure you've puled in the safety lever before pulling on the cord .. otherwise, it shouldn't budge.. Hope this helps..
Sep 22, 2008 | Washing Machines
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
