Question about Brother IntelliFAX 4100 Laser Fax
Brother fax 4750e can not receive or send fax. sender said the line just ring and ring endlessly
  • 1,959 Answers
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
Posted on Apr 23, 2009
When we send and receive faxes via our Brother Intellifax 4750e, there is a large black line on the right of the page.
hello, if this line is larger than 1 inch, and you already checked toner and drum, then the problem will be the actual scanner, this unit will need to be replaced,
Sep 29, 2010 | Office Equipment & Supplies
The brothers 5750e fax will send fax but not receive them. What setting are needed to correct this problem. This is a dedicated fax line.
make sure the sender has the right phone number. Set your machine to AUTO or press the START button when the fax machine rings.
Jun 09, 2010 | Office Equipment & Supplies
Need to program to date stamp incoming emails
Hi Deanna, unfortunately it is not possible on this unit to have the date and time stamped as that is produced by the senders machine, this feature is referred to as the station ID on your brother machine.
Mar 26, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Our IntelliFax 4750e will not receive faxes. The line has a dial tone, and rings when called. It is set to "fax" and not "fax/tele." Suggestions?
There are a few possibilities. 1) The phone cord coming from the wall is plugged into the phone port on the fax instead of the Line port. It should be on the line port.
2) The fax have been set for distinctive ring. This causes the fax to ignore the normal incoming ring tone and is instead waiting for the distinctive ring from the phone co.
3) The modem in the fax has gone bad. If you have had any power failures or electrical storms/problems this is a possible cause.
Some models will also not answer if the machine is out of toner or paper.
Oct 21, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Our brother intellifax 4750e fax machine will not
It is probably set to manual receive, meaning you have to pick up the receiver, then hit start to receive the fax. I'm sorry I don't know specifically where to find this setting on your model but if you can find it in your menus, you should be able to switch to auto receive to eliminate this.
Oct 15, 2009 | Brother Office Equipment & Supplies
Able to send fax cannot receive fax
make sure phone line is pluged into line on fax,make sure fax is set auto.there should be a button on fax panel that say's receive mode.
Sep 07, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Receiving faxes
The memory may be corrupted which is affecting the it receiving incoming faxes - to clear the memory: 1. Press the Menu/Set and Fax Resolution keys in this order. 2. Press the 0 key. 3. Press keys 91 (Parameter Initialise will appear in the display)
Sep 07, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Receiving Faxes
Can you receive a voice call on the same line? Call the machine with your cell phone and see if it rings and you can hear your voice on the fax receiver. Use your manual to check the settings.
Feb 23, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
729 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
