Question about Daewoo L700C 17" Flat Panel LCD Monitor
Screen goes black, but power light is on (not blinking)
Dell E173FPb. I turn it on, screen looks great, stays on for 3 seconds, then goes black. Power light is still green, not blinking. I can turn it off, and then turn it right back on again and it works. Then, after 3 seconds it goes black again. What can be the problem?
  • babohman Apr 30, 2009
    The problem is not the Video card. It is the monitor. I have 4 computers in my house, and have connected it to all of them. I get the same results. I have been in the IT field for nearly 10 years. Normally I just throw the monitors out when they stop working properly, but my Client does not want to buy a new one at the moment, and I for some reason am curious as to what causes the problem and if it is reasonable to try and fix. As I am not billing the Client hourly, I am not worried about the amount of time it takes to fix, and they wouldn't care either. I have heard that it may be a problem with the transisters or transformers on the monitors board. Any thoughts?
  • Eddycalix Aug 04, 2013
    I have the exact same issue with my zenith, ive been on the web trying to figure out what is causing this to happen, but people keep giving the same response. No clue?! I wish i knew so that i could get it over with, could it be the bulb?
NEED A NEW MONITER
Posted on Nov 29, 2015
    Problem Solver:
Achabacha, It's not true what you just said.. because i had the same probleme, i did try the screen on another computer, always it goes black after 3 to 5 seconds, so i guess the probleme is with the sceen
Posted on Dec 10, 2014
    New Friend:
  • 113 Answers
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Posted on Apr 23, 2009
  • glenpado
    glenpado Jun 04, 2012
    Same problem with my hp lcd L1710 after turn on the screen turn to black the power is still green. turn off and on again it will on after 3second will black again. i suspect is the pc but i change the lcd it work in the other lcd so its not the cpu is the problem is the lcd. but i dont know to fix it.
When I turn on the power my E173FPb lights up for only one or two seconds and then goes black and the green on-light remains illuminated. try on other computers same thing, am i wasting my time fixing was...
Hi there! You can test first if the monitor is working. Disconnect it from the computer then turn it on after that it should show you colors on the screen this means its working if not then its no use trying it on a different computer.
Hope this helps!
Sep 06, 2011 | Dell E173FPb 17" TFT LCD Monitor
MY DELL E173FPb FLAT MONITOR WILL NOT COMPLETELY POWER UP IN GOES
Most common failure in this model is shorted transistors in the inverter circuits caused by poor solder connections, see pictures here for guide: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Mar 27, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor keeps turning off but power says it's still on
You are OK with the power cord, more likely to be failure in the power supply/Inverter board, look for bad fuse and shorterd transistors, see Dell pictures here: http://s807.photobucket.com/home/budm/allalbums
Transistors should be checked out off circuits.
Mar 16, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Apr 10, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell Monitor 1907FPt comes on for a short time and goes to a black screen. Power light is still on. How do I fix this?
HI
YOUR PROBLEM IS NOT INVERTER BOARD IT IS MOST LIKELY THE LAMPS, ANY 19" LCD LAMP THAT FITS WILL FIX IT FOR YOU.
THANKS
AHMAD
Mar 01, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
My Dell Monitro goes black about 4 seconds after being turned on
Hi..there,
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it.
Nov 12, 2008 | Computers & Internet
Dell flat screen
REPLACE 2SC5707 IN POWER INVERTER BOARD.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
May 01, 2008 | Dell E173FPb 17" TFT LCD Monitor
Monitor Goes Blank after 30 mins....
http://www.electronicrepairguide.com/dell-e173fpb-lcd-monitor-repair.html
Dec 12, 2006 | Dell E173FPb 17" TFT LCD Monitor
Daewoo L700C 17" Flat Panel LCD Monitor Logo
1,966 people viewed this question
Top Daewoo Computers & Internet Experts
John Anderson
John Anderson
Saleem Baig
Saleem Baig
JonSnell Electronic
JonSnell Electronic
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
