Question about Smartpool Nitro Robotic Cleaner and Caddy
My nitro xl works great but recently when it climbs the wall it comes right out of the water.
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: Nitro N71 does not climb
None of the robotic cleaners are going to climb that surface well. Off all the options out there the Aquabot with the foam brushes is likely your best option for an acrylic pool. The Dolphin version can have rings added to their brushes but that may not be enough. You may try to get a rental unit from a local shop or pool store to try out before committing to the purchase so you will know if it work before buying it.
John
Posted on Oct 23, 2010
Why does the n71 not climb walls or slope
check drive belts or worn out paddles if ok check inside to see if motor is weak
Jun 24, 2014 | Smartpool Nitro Robotic Cleaner and Caddy
My Gw9500 won't climb all walls in my pool
get one of your kids to do it by hand. Those things never do anything except destroy your pool and income.
Jun 10, 2014 | Pentair Kreepy Krauly Great White GW9500
The dolphin maytronics does not climb the wall
Thank you for posting your question here on Fixya.com.
Several possibilities to consider...
How old is the filter bag and is it clean?
Older bags or bags not thoroughly cleaned can resist water passing thru them to the point there is not enough downward pressure to allow the unit to 'bite' the pool surface and climb.
How worn are the brushes and tracks?
Worn brushes and tracks will slip once worn enough. Replacing them could fix the problem.
Is it trying to climb or does the unit start up the wall and immediately reverse?
If your motor has been replaced new style motors spend far less time climbing assuming most debris will instead be found on the pool floor. If it has not been recently replaced the program within the motor may be failing.
What is the condition of the pool?
Low water temperatures and/or algae can cause the unit to slip in place and as a result it will not climb. Eventually it will scrub enough to gain traction and will slowly progress up the wall. For temperatures below 70 degrees the unit will find in more and more difficult to climb the lower the temperature.
What material is the pool surface?
Some linered pools and fiberglass pools require climbing rings in the brushes. Do you have those? If so, what condition are they in? Worn rings or missing rings will prevent climbing those and other smooth pool finishes.
For more troubleshooting tips try our site at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin. You can also check the manufacturer's site at www.maytronicsus.com.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
Dec 31, 2010 | Dolphin Maytronics Diagnostic Robot...
Wont climb wall
Nov 23, 2010 | Dolphin Maytronics Advantage
My cleaner works for a few minutes, climbs a wall and rolls over onto it's head.
If the problem always occurs when the pool cleaner starts to climb walls, there are a few things that you will want to check. First of all, if your pool has a vinyl liner, this pool cleaner has limited climbing ability. You need to check the flow of water through the cleaner with your flow gauge. It might be low. If it is, increase the water flow. Also, make sure that your hose weight positioning is correct. The cleaner should sit at a 45 degree angle at the bottom of the pool when resting when the weights are right.
Nov 08, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Nitro N71 does not climb the walls of my Acrylic mosaic swimming pool. I fitted the replacement front and rear paddles with the foam wheels but this did not do the trick.
John
Oct 21, 2010 | Smartpool Nitro Robotic Cleaner and Caddy
What is the difference between the red light and green light?
my wall climber only wants to climb the walls. it won't run in a straight line. it only cleans a small part of our pool.
Jul 06, 2010 | Smartpool Nitro Robotic Cleaner and Caddy
My dolphin begins to work, then stops. What could
There are several problems that could make these automatic pool cleaners fail to climb the walls. The cleaner could be too heavy. Empty and wash the filter bag and add floats if necessary. Make sure there is no water in the handle and that the brushes arent worn. If the cleaner is too light, add weights. If there are excessive amounts of algae on the wall, you will need to brush the walls first. The algae can prevent the cleaner from climbing. Make sure that the temp is at least 65 degrees in the pool. Make sure there is nothing caught in the impeller.
Jun 14, 2010 | Dolphin Maytronics Advantage
Smartpool Nitro Robotic Cleaner and Caddy Logo
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
