Question about GE Ovens
I need a thermostat for a 1970's GE double wall oven. Can't find one, everything says it's "no longer available". Model # JK29009HT Scott
  • 69 Answers
SOURCE: need instructions on my GE profile wall oven
GE.COM really helps
Posted on Sep 20, 2009
heatman101
  • 43501 Answers
SOURCE: ge jtp48 double wall oven controls wont work after
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
heatman101
Posted on Apr 26, 2010
  • 5127 Answers
SOURCE: how to install GE JKP35DPBB 27" Double Electric
The specs for this double oven give a rating of 5.1kW at 208V so it needs a 30 Amp circuit breaker. This assumes that the oven is the only appliance on the circuit. So you should be able to use the same circuit breaker.
A bigger consideration is that the opening for the double oven needs to be larger than that of the single oven. If the opening does not have a solid bottom, it must be able to support a heavier load. The runners and braces under a single oven has to support 200 pounds (91 kg). A double oven must have braces and runners designed to hold 375 pounds (171 kg).
Also check if your household uses aluminum wiring. The new oven has copper and problems will occur at the interface if you do not use the appropriate precautions. (Products designed for mating copper and aluminum are available - follow the directions).
I hope this helps.
(btw: you can find the User's Guide and Installation manual for the double oven at GE's website: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JKP35DPBB . See the section Literature and Manuals on the left hand side of the page below the picture of the oven.)
Posted on Oct 29, 2010
  • 1891 Answers
SOURCE: I have a GE Profile
i don't think so. the oven's tempt control is ( the clock and it controls both ovens.) there is a sensor in each oven and they tell the clock what is going on it each oven. if both oven are not correct in there tempt you could replace the sensors first and then the clock. now if cost is a factor I would replace the top oven sensor first and see if it corrects the problem . and if so repl the bottom . and if the first sensor does not correct problem then you need the clock.( e o c ..electronic oven control .) this will not be a cheep repair . sensors are 70.20 ea and the clock 201.60 == hope this has helped mm feed back pls . part # of sensor wb23x5340 and clock wb27t10287 //
Posted on Oct 31, 2010
espressonist
  • 1711 Answers
SOURCE: Ge double wall oven, model
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Jan 01, 2011
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
How do I uninstall a GE double wall over?
The instructions come with the oven. And differ with models. Most important to follow all items. If the instructions are lost , Google GE double wall oven ( give model number). Or try the GE Dealer.
Aug 23, 2014 | Ovens
My GE #JRP15WOP2WG wall oven, manufactured in about 1995, only starts heating if I put the temp at 550. It gets extremely hot, then I have to turn it down to 520 in order for it to click off. Unfort
Good Morning! I would check the oven temperature sensor first. There are a lot tutorial videos that can be found by Googleing, "How to test my oven temperature sensor." If the sensor is good, and reads 1100 ohms at room temperature.. then the issue youre experiencing is likely control board related. Given that the part is no longer available new, the oven board will have to be rebuilt. Fixyourboard does this and offers a 2 year warranty with each remanufacture.
WB27K5073 GE General Electric Oven Control
May 14, 2017 | GE 30" Built-In Single Electric Wall Oven...
Double wall oven: Model JKP26GOP13G. The upper oven heats but not up to the setting input. If setting is 350 F, for example, the stove only gets to around 200F.
I trust the door is sealed correctly. If heat is escaping this could be the problem. If the seal is okay the only thing it could be is the oven thermostat controller. It sounds like it is faulty and needs replacing.
Feb 12, 2011 | GE Ovens
How to install GE JKP35DPBB 27" Double Electric
I hope this helps.
Oct 29, 2010 | GE 27" Built-In Double Electric Convection...
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
We have a double wall oven which is 16 years old. The top oven doesn't heat above 150 and the bottom oven is overheating...the oven said 375 and an oven temperature gauge said 450. Is this fixable or do I...
I have the same issue. Only answer I found was the elements may be burned out. The bottom oven is separate (knobs).Go to GE site and see how to adjust the thermostat (behind a knob).
Nov 01, 2009 | GE JKP27 Electric Double Oven
Do you sell parts for a Kenmore built-in double wall oven - a 1992 model from Sears? They no longer carry the control box
Maybe we can help you.
We rebuild "no-longer-available" oven controllers at www.fixyourboard.com.
Sep 04, 2009 | Kenmore Ovens
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Mar 24, 2009 | Ovens
Bottem Oven Over Heats
GE announced a recall for some of its wall ovens this week for an overheating problem. Have you contacted a GE dealer yet?
Nov 20, 2008 | GE JRP24 Electric Double Oven
Ovens Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
