Question about Home
How to set Levenger calendar clock - Home
3 Suggested Answers
cuppajoey
  • 3 Answers
SOURCE: HOW TO SET A CLOCK AND CALENDAR ON SHARP EL-1750P CALCULATOR
GT •RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR:
“GT”: Grand Total
“•”: Neutral
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Sep 19, 2008
  • 3 Answers
SOURCE: Setting the Canon MP25DV clock and calendar
press clock/calendar once to set date
1) press equal numbers will flash then use number keys to current time then the X to set am and pm. press = again to set time
2)press clock/calendar until date flashes. use number keys to current date. Press = to set
Posted on Jan 13, 2009
Need manual for levenger tube radio / clock
Levenger might be able to supply a manual
Aug 09, 2013 | Audio Players & Recorders
How do I reset the time and calandar?
press the calendar/clock key (top row, second from the left)
press the "=" key (clock/date set) and hold till display flashes
key in the correct date
key in the correct time and remember to select AM or PM (#/diamond key)
CE/E returns to calculator function
Oct 11, 2012 | Canon P170-DH Calculator
How do you set clock on a lg rumor cell phone
Here are the instructions for changing the clock display. I'm sure somewhere along the way you can set the clock too.
1.
Press Menu > Settings/Tools > Settings > Display >
Main Screen > Foregrounds > Clock & Calendar
2. Select Normal Clock, Analog Clock, Digital Clock,
Dual Clock, or Calendar, and then press Menu/OK .
3. Press Menu/OK to apply the clock display setting.
This came from the manual for the LG Rumor at this link:
http://www.cellphones.ca/upload/manuals/lg-lx260-manual.pdf
Jul 21, 2010 | LG RUMOR Cellular Phone
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Install setting for Clock and Calendar
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
Your Owners manual
Setting the date
The calender display adjusted in this mode appears
when the telephone source is selected
or sources and the feature demo are off.
1 Use MULTI-CONTROL to select
Calendar.
2 Push MULTI-CONTROL left or right to
select the segment of the calendar display
you wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the calendar display:
Day—Month—Year
As you select segments of the calendar display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the date.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
select the segment of the clock display you
wish to set.
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
put a clock right.
Note
You can match the clock to a time signal by
pressing MULTI-CONTROL.
! If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes 10:00.)
! If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
Jan 01, 2009 | Pioneer DEH-P7900BT CD Player
Nov 02, 2008 | Canon MP-25DV Calculator
Canon P23-DH
I don't think the P23-DH has a calendar/clock mode. I have found the instructions for setting date and time for the P23-DH V. If your calculator does not have [Calendar/Clock], [Time Set], and [AM/PM] keys, you cannot set the date and time.
To set date:
1. Press the [Calendar/Clock] key once
2. Press and hold the [Time Set] key for three seconds
3. Enter the date in MMDDYYYY format
4. Press the [Time Set] key
5. Press the [C/CE] key
To set time:
1. Press the [Calendar/Clock] key twice
3. Enter the date in HHMM format, press [AM/PM] key if necessary
Aug 27, 2008 | Canon P23-DH Calculator
Time/Date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display1.gif will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Feb 20, 2008 | Sharp EL-2630P Calculator
Set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
Nov 27, 2007 | Sharp EL-2630P Calculator
Home Logo
258 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
