Question about Maytag Washing Machines
Washer wont spin I have a maytag mvwx700xlo - Maytag Washing Machines
4 Suggested Answers
duby1990
  • 367 Answers
SOURCE: My MayTag performa oversized capacity washer wont spin
Usually this is caused by the pump being cloged or broken. Remove the pump and clean the pump out. Make sure it spins freely by hand.
Posted on Nov 21, 2008
landsend
  • 1066 Answers
SOURCE: maytag atlatis mav8551aww washer runs fine til spin mode then
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
SOURCE: maytag bravo washer model number MTW6700tQ0 wont finish spinning please help!!
Hello c bellone,
If you rotate the clutch pulley by hand CW the tumblers should rotate in the wash basket.If you rotate the clutch pulley CCW the tumblers will rotate until the clutch spring comes under tension then the wash basket will begin to turn CCW and the tumblers will stop rotating because the transmission rotates with the wash basket. Do you have this action?
The clutch has been an issue for many are you taking dc or UC errors to the display?This clutch incorporates a Drawn Cup Roller clutch bearing (one way clutch bearing) designed to rotate freely CW and lock up CCW to rotate the spinner shaft in spin cycle rotating the wash basket/transmission CCW.You are halfway thru the clutch removal process, I would drop the clutch out and inspect the roller clutches, clean them up with WD-40 and some light bearing grease.If they are rusted up beyond clean up and or the clutch spring is broken as in this post you will have to replace the clutch.You will know what you are up against once the clutch is out and opened up for inspection.
Here is the process I use for clutch removal;
Access and remove the Clutch for maintenance
Disconnect 120VAC power cord.
Posted on Nov 27, 2012
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
My Maytag bravos wont spin out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag Neptune washing machine - wont drain & spin
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Wont spin
If it's NOT a direct drive machine, then your problem is most likely with the Wig-Wag switch, located on top of the gear case! It ALWAYS goes bad and effects the Spin function.
Aug 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Matag top load washer wont spin or empty
Set the timer for manually for the spin cycle and trun it on.
If it does not spin replace the lid switch.
Mar 14, 2009 | Maytag Washing Machines
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
Maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
