I have got a new emprex monitor eveything is working but no sound is coming out. ive connected the speakers from the old monitor the light is coming from the speakers but still no sound
  • 123 Answers
Have you connected the speakers on the monitor to the sound card on your tower
Posted on Apr 23, 2009
My 1000 watt amp is hooked up powers on eveything is connected to the head unit but no sound comes out the sub im thinking the rca jacks r broke
check RCA wires for breaks or bends especially if they are somewhat old and used test speakers on a 9 volt battery to see if the pop and flex and push them straight in and out to see if you hear any scratching sounds
Aug 20, 2011 | Car Audio & Video
I bought my emprex monitor 3 yrs back. For all these years it had worked its best. But now, when the computer is powered on, the screen flickers by producing small poping sound and goes black...please...
Yes it can be repaired usually just easier to by a new one. it sounds to me like it is a power supply for the monitor. The only hard thing would be getting the power supply for the monitor. Your can try contacting the manufacturer for it :) hop this helps
Dec 27, 2010 | Emprex LM2201 22" LCD Monitor
Emprex monitor lm 1905 - blacks out after a
If this has an internal power supply (no external brick) then you probably have failure of the capacitors inside. The problems exhibited by these failures are usually summed up as "works for a short while and quits" or "will not come on". Yours is probably similar to some Gateway monitors that I have repaired, The parts required for the repair should be under $10.00 and should take under an hour. Now you need to find a shop that can and will do the work unless you have soldering skills.
Dec 05, 2009 | Emprex Computers & Internet
My emprex monitor has power but the image wont stay on. the screen somes on, shows an image for about 2 seconds then goes black.
This sounds like a backlight problem. I've had this with an acer laptop before and it needed a new backlight replacment under warranty.
Also check things like the connection cable, try it with a different pc, try a different (lower) screen resolution in case it's not compatible.
Nov 08, 2009 | Emprex LM2201 22" LCD Monitor
Compaq JBL Platinum Series Speakers not working on Windows Vista
change the audio and sound device setting in the control panel. try to change the speaker setup
Oct 05, 2009 | HP JBL Platinum Computer Speakers
No Sound from speakers BUT sub is working fine?
try to unplug and then plug again all the speaker's connections...make sure you do the right connections...or get a AA or AAA size battery,put the + side of battery to the + of speaker(alone/unplug),and momentarily touch the negative(-) side of battery to the negative(-) of your speaker,,you must hear a click from your speaker...if there's no click,you have a defective speaker..
Feb 08, 2009 | Altec Lansing VS2421 Main / Stereo Speaker
I NEED A DIAGRAM TO CONECT SPEAKERS TO PC
I'm afraid that the way the sound system is set up in microsoft control panel, you have to chose between external speakers on or the the built-in speakers on. check there under sound, but I don't think that there is an option to have both on
Mar 03, 2008 | Audio Players & Recorders
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
make sure you hook up the third gree socket on back of monitor to PC that was my problem and solution to my model monitor LCD
Sep 17, 2007 | Liquid Video E15LCD1 15"
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
