I have not success to connect a front panel cables in 945LM4 Boards
    Brigadier General:
  • 3,400 Answers
Vertical lines on a pansonic tv model # TC-P5OS1
Bad Panel----this is fatal cost wise.
Bad connections where ribbon cables connect panel to boards.
Communication problem in the set between main digital board and other boards.
May 16, 2012 | Televison & Video
How to wire front panal
You will need to open the computer case and check that the cables that run from the actual power button to the motherboard are plugged into the proper spot on the motherboard. Sometimes reseating the cable can fix this issue.
I think this is the link to your motherboard documentation: http://www.via.com.tw/download/mainboards/3/4/p4mapro533_r100.pdf
Check the page 2-14 or 2-15 and see if that helps you to identify the actual connection for your power switch.
Nov 14, 2011 | VIA P4MA Pro Motherboard
I have an ICOM-504 . I can transmit but I can not receive any chanels even the WX is not receiving
I had the same problem and traced it to a bad connection between flex cables and boards.It seems the SQL signal from the Rx board is not reaching the processor on the front panel. Check all connections (reseat all cables) and try again.
servstan
Aug 09, 2010 | Icom IC M504 Black Submersible PLUS Marine...
My panasonic viera tv has two lines running top to bottom what are they and how do i get rid of them or is it knackered
If you pull up the tv menu are the lines visible in the menu. check the connectors on the c boards accross the bottom to the flex cables to the panel. Be sure to disconnect the power supply from the sustain boards before you mess with these because the stored energy from the power board will burn the flex cables to the panel and you will have to replace the panel. So be sure power supply is disconnected from the sustain boards and the sustain boards are disconnected from the c boards. Be sure to reconnect everything before power back on. Double check sustain board couls be damaged if not reconnected. This tv is known for connections loose to the panel from the c boards at the bottom. Next would be to replace the c board that corresponds to the stips. If that does not fix then The panel is bad.
Mar 25, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Samsung 50 in. HPS5033X/XAA colored lines running vertically and won't go away.
How wide are the lines. Do they change width? Where on the screen are they located?Connections on the c boards at the bottom to the panel flex cables or bad c board itself can cause 2 inch wide verticle bar. Before touching these connectors be sure power supply is disconnected from the 2 sustain boards on the sides. If you don't there will be an arc that will destroy the flex cable thus you will have to replace the panel. If C boards or connections don't fix it the replace the plasma panel. If the lines are thin lines then panel is likely bad. Contact Panasonic even if out of warr they may help.
Dec 06, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Half of my tv screen is not showing a picture
Check the connections on the buffer boards to the panel. Likely connection or bad buffer board.Change buffer board . If this does not fix then Panel is bad. Try C board connections on bottom. Be sure to disconnect power supply from sustain boards before messing with these connectors to avoid burning the flex cables.
Oct 31, 2009 | LG 50PX5D 50 in. Plasma HDTV
I HAVE A IOMEGA HARD DRIVE FOR MY MAC (TIME MACHINE) MODEL NO. MDHD10T-UE AND HAVE BEEN USING IT FOR SOME TIME HOWEVER IT HAS NOW GONE OFF MY SCREEN AND I CANNOT RETREAVE IT I HAVE TRIED CHANGING THE...
Hi I had one which my son connected the wrong power cable to an toasted the boards inside. I had to strip it and get new boards for the hard drives inside and replace them. i have managed to recover one of the drives ie 500gb.
Oct 11, 2009 | Office Equipment & Supplies
Red Line, intermittent
Dust will not ever cause that problem.
It sounds like your driver board/assy boards/video board inside maybe faulty or the cables have come loose.
The driver board/assy boards feed the display panel with the images.
The video board decodes the input signals, when you say its intermittent I wouldn't say it was the panel more the video board or the driver board/assy boards.
Just call the manufacturer and they can get a service engineer out to resolve it or get a replacement organised for you with the manufacturer with no problems as you are still within your 12 months warranty period.
Thanks
Oct 01, 2009 | Televison & Video
MSI 915o comboAudio front panel
Some cases come with a Mic & speaker jack/ cable. These jacks sit within the case. Rather than using the rear Mic which is (colored pink) & speaker (colored green). These 2 colored cables run from the front of the case & out through an emty hole in the back of the case. Which you connect them to the rear of the boards Mic in (pink) & sound (green). Now you can use your front audio jacks for both mic & sound. This may sound strange but I have come across many cases just like this. Its not uncommon to have 2 front usbs & a 1394 connect on to the board as well. Without your manual I'm sorry I can not help you fauther.
Jan 02, 2008 | MSI 915P Combo-FR Motherboard
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
