Question about XO Vision GX1042 10.4 in. Car Monitor
My screen just says no signal as I can fix that problem
It has "V1.43 Pace PR150BNM SysCode Loader" Pace. Across the top of blue screen, what's up?
Element Electronics blue screen no signal Questions ... - Fixya
www.fixya.com > Forum > Tags > blue screen no signal
Blue screen with ''component 2'' in a box shows. Then it goes black.There is also a humming coming from the tv. I have unplugged everything from the tv, and ...
element tv problem - YouTube
? 2:26
https://www.youtube.com/watch?v=2FnqRRcQzNs
Feb 17, 2010 - Uploaded by pacman552sd1
... is a vid im attaching to my email to custamer support to try and fix my bad tv. ... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW ...
Dish Network - My element TV is saying "no signal". ' Directly
Jan 09, 2016 | Element Televison & Video
The tv is stuck on this screen with the error message weak or no signal I need help on the steps to fix it
I can't read the screen, but weak or no signal means the signal coming in from the cable box or outside antenna is not good.
You would need to check the box and the cable connections.
Dec 19, 2012 | Televison & Video
Screen dose not come on
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Salim Tanay.
Your problem is most likely due to the following:
No signal: Fix by removing the graphics card and cleaning the gold fingered connectors with tissue paper. Use a vacuum cleaner to clean the slots.
No signal: A loose connection.
No signal: A damaged mainboard.
One can also try to fix the problem by clearing the BIOS/CMOS.
See my published guide below:
How do I reset my BIOS/CMOS to defaults?
Take care!
Apr 18, 2012 | Samsung Computers & Internet
The image on the screen looks like everything is in slow motion, the the color is messed up. I have already tried adjusting contrast, brightness, etc. Is this a fixable problem, or should I just buy a...
I know the colors are all messed up.But the tv LCD screen panel light it is bright enough to see the screen picture,and the tv LCD screen panel are clear,no purples,reds marks or bruses to the tv LCD screen panel itself?Yes,to all of these.The tv can be fixed.The tv Tuner signal board,that the board where the incomming broadcasting signal wire plug into it.The tv Tuner signal board it is dying and the problems to causes this.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.Will fixed this tv and get tv this to be working normal again.
Aug 20, 2011 | Samsung LN-T3253H 32 in. LCD Television
Trying to set up Panasonic TH-L32X10A LCD TV. Have plugged into the wall and the screen display says 'No Signal'. How can I fix this? Thank you.
chose the input from the lcd operation on screen manual that is proper for the signal you are using (example) hdmi, AV, or TV. when you choose the correct input selection the lcd will show what ever signal you are sending it.
Apr 18, 2011 | Televison & Video
Vizio TV with Blue Screen says, "Aucun Signal!"
Guys aucun signal just means no signal in french
Mar 01, 2011 | Vizio L37 Television
I have an insignia 19 in lcd tv My tv was given to me broken. What it does is once you turn it on it will say please wait and then the screen will go black and that's it what should I fix to fix the...
The tv LED power light indication still on,have a solid color,but the LCD screen panel goes black?Yes,this problems and the causes is the tv Tuner signal board have a shorted part or parts some kind inside it circuitries and it dying.The tv Tuner signal board,that the board,where the incomming broadcasting tv signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 04, 2010 | Insignia NS-LCD19 19 in. LCD TV
DVDirect recorder. waiting for input signal? It shows the video on the screen but i push the record button and it stops and says waiting for input signal?! help!!!!
HAD the same problem! Called sony and it was fixed for me. I had a/v wires hooked up from my camcorder and from my vhs. I could see the video on the DVDirect screen. I would hit record and screen would go black and say "waiting on input signal". The fix: 1. turn the unit on. 2. Hold the on/off button for 30 SECONDS. (YEP, believe it or not) When I hooked the wires back up and did the same thing I had been doing. IT WORKED!!!! Hope it works for you!
Sep 22, 2009 | Sony DVDirect VRD-MC3 DVD Recorder
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
No signal are you in a building? how to fix?
have a look at the menu at the saterlite part you need at least 3 saterligths fixed to have a signal im betting you don,t have any
Jan 25, 2009 | Tomtom ONE 3rd Edition GPS
XO Vision GX1042 10.4 in. Car Monitor Logo
Top XO Vision Car Audio & Video Experts
mega_mind
Andy
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
