How do i open the sides of my sony vaio pcv-1122? there are 4 'screws' on each side, each with a star shaped hole in the middle , however an allen wrench doesnt' seem to work. i am trying to add memory.
    Problem Solver:
  • 17 Answers
You need a special type of screwdriver for this which is called Torx. You should be able to get one from any DIY/ hardware store
Posted on Apr 23, 2009
How do I open my sony pcv-v1
1. Ground Yourself
2. Unplug everything and press the power button for 10 sec to
discharge any residual power.
3. Place PC face down on bench with base over edge.
4. Swing PC unit forward and unscrew the case retaining screw on both
sides of the PC unit, swing unit other way and remove other two
screws.
5. Case can be loosened, pull large cover up and remove both sides.
Parts are then exposed.
6. A shiny metal box covers the memory on the left side of the PC unit. 7. Remove tape that retains it,slide and lift off from the edge facing you.
8. Memory slots are then exposed....insert and reassemble PC.
Good Luck!
May 14, 2012 | Sony VAIO PCV-RX403N PC Desktop
How to dismantle sony vio desktop
This model simply requires the removal of the purple screw in the back side of the pc. Then, the side of the case would pull towards you.
Nov 07, 2010 | Sony VAIO Digital Studio PCV-RX660 PC...
I have a Sony PCV-V300G with a bad DVD drive but don't know how to safely remove the rear cover. I removed the 2 1.25" screws at the lower edge or each side but no go. I Don't want to break anything. Any...
after you remove the screws, check every middle side if front, ther must be a hole in the mettle where is attached frome inside a plastick switch that holds it all together, pushe them on by one( opposit ones first), with somthing strong untill the are unleshed frome the metal, then remove the front end...and then its all done....
there might be some small other details u cannot apply this solution on all drives **** its the basic way....
May 07, 2010 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
How do I remove my DVD burner for replacement from my Sony VAIO PCV-RS720G? I get the two little screws out from the side, but then something hangs it up. Can't find what the hang up is. Thanks. Segalhund...
Segalhund, I appreciate your wanting a solution, but please refrain from stating your email addy.
There are three screws.
Facing the back of the computer.
One at the Top in the middle of the case cover.
One down on the Right side, straight across from where the monitor plugs into.
One down on the Left side straight across from where the monitor plugs into.
The cover is shaped like a hood, and slides towards the front of the computer.
I'm looking at the User Manual for the Sony Vaio PCV-RS720 Desktop PC right now.
This is Sony eSupport, and the download page for the Vaio PCVRS720G User Manual,
http://esupport.sony.com/US/perl/model-home.pl?mdl=PCV-RS720G&region_id=1
On this page left-click on Manuals, Specs, Warranty. (In blue to the upper right of the page)
On this page under the heading - Manuals -
left-click on - VAIO User Guide - in the list.
This is a PDF file. It may take as much as 30 seconds before you see the first page. Suggest you let it download all the way before looking through it.
Page 87 shows removing the cover.
Mar 28, 2010 | Sony VAIO PCV-RS720G (027242658103) PC...
Replace a new dvd burner into Sony Vaio desktop PCV-RX755(UC)
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVRX755&region_id=1.
this link will let you download users guide.all I could find .
Mar 06, 2010 | Sony VAIO Digital Studio PCV-RX755 PC...
How you open a sony PCV-RZ22G
Sony has a description of how to open the computer here. Looks like you don't need any screw driver at all.
Enjoy!
As much as I appreciate your rating, if you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 31, 2009 | Sony VAIO Digital Studio PCV-RZ22G PC...
How to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
No Allen Wrench in my possession fits these holes
Yes, there are tools called "Allen" wrenches. They come in sets.
Mar 13, 2009 | Sony VAIO Digital Studio PCV-RZ22G PC...
SONY VAIO PCV V1G
Model:PCV-V1/G
Unplug everthing and place PC face down on bench with base over edge. Earth yourself.
Swing pc unit forward and unscrew the case retaining screw on both sides of the pc unit, swing unit other way and remove other two screws. Case can be loosened, pull large cover up and remove both sides. Parts are then exposed. A shiny metal box covers the memory on the left side of the PC unit. Remove tape that retains it,slide and lift off from the edge facing you.
Ten minutes tops....good luck, much better performance.
Apr 03, 2008 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
Computers & Internet Logo
648 people viewed this question
David Payne
David Payne
