Question about LG 32LC5DC 32 in. LCD HDTV
Cannot get lg 32lc5dcs to connect to pc - LG 32LC5DC 32 in. LCD HDTV
Tv lg 32lc5dc not turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
May 24, 2016 | LG 32LC5DCS 32 in. LCD TV
Lg 32LC5DCS wont power off
Do a reset to this TV and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 12, 2014 | LG Televison & Video
No video only audio
Back light not working check inverter board, dry solder or bad connector
Aug 09, 2011 | LG 32LC5DCS 32 in. LCD TV
LG PC Suite does not detect the LG KS360 phone!
You need to change the usb connection type on the LG. By default it is set to "mass storage", if you change it in your "connection" setting to "data storage" when you next plug in your phone, it will have all of the PC Suite settings available without any grayed out non-functionality.
Jul 22, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
I can't connect my lg viewty with the refreshing problem to my pc
please try to connect your lg to some some another pc, perhaps it will work, keep it up
Jul 13, 2009 | LG KU990 Viewty
Connect the lg mobile to pc
HAI,TO CONNECT INTERNET THROUGH CABLE OR BLUTOOTH.
(i) 1.CABLE : INSTAL DRIVERS FOR THE CABLE AND LG PC SUITE,RESTART PC THEN CONNECT DATA CABLE BEDWEEN PC AND MOBILE.IT,S ORIGINAL CABLE DRIVERS ARE AUTOMATICALY INSTALED,ORDINARY CABLE MANUALLY INSTAL DRIVERS.
2.THEN FOLLOW TO CONNECT INTERNET:
   START>CONTROL PANNEL>SELECT NETWORK     CONNECTIONS>SELECT CREATE NEW CONNECTION>FINISH.RESTART PC AND THEN CONNECT INTERNET THROUGH NEW CREATED IN NETWORK CONNECTIONS.
(ii)VIA 1.BLUTOOTH:INSTAL BLUTOOTH SOAFTWARE(BLUE SOLI) AND RESTART PC.
2.ON BLUTOOTH ON MOBILE AND CONNECT MOBILE TO PC (BLUESOLI).SELECT DUN INTERNET CONNECTION TO INTERNET.
Jun 30, 2008 | Computers & Internet
LG 32LC5DC 32 in. LCD HDTV Logo
21 people viewed this question
Computer Repairing
Computer Repairing
