Question about Kohler Electrical Supplies
5EKD MARINE OVERLOAD - Kohler Electrical Supplies
I need an electrical drawing of a Mercury Marine harness p/n 896537t15 also p/n892990T01. I'm replacing engines and trying to get my ducks in a row.
I can usually find most things to do with marine engines, but your is a problem with just a part number to the harness.
The correct search would be something like
19696 Mercruiser sterndrive wiring harness, or schematic or wiring diagram or workshop manual.
Personally, I would say it is a job for a marine engineer who has the manuals. You could also try Mercury Marine direct. Sorry to not to be more help.
Wire Harness For Sale
Mercury Marine harness 896537t15 schematic Google Search
From my own contact with Mercury Marine over a warranty repair, they seem to genuinely care about the customer.
Mercury Marine
Aug 01, 2017 | Mercury Boating
What are the main manufacturers of gasoline engines for boats?
The main manufacturers of gasoline engines for boats are: Crusader Engines, Flagship Marine, Ilmor, Indmar Marine, Marine Power, Mercury Marine, PCM Marine Engines, Teague Custom Marine, and Vovlo Penta. For more information on these manufactures, check out this website: http://marinefuel.com/marine-engine-manufacturers-gas-or-gasoline/ and http://www.discoverboating.com/buying/types/engines.aspx?id=79
Feb 06, 2013 | Boating
My radio would not turn on yesterday. I have checked the fuse and fuse connections. The fuse was black, so I put a new one in. The fuse connections were good. The connections to the battery are good, the...
The black fuse means it blew from a fast, heavy short circuit instead of an overload of some sort. The high current vaporizes the wire inside and coats the glass, giving it the black look. In an overload, the fuse link melts.
A common cause is failure of the reverse-polarity diode in the radio. It's there to cause the fuse to blow if you get the battery connections backwards when hooking up the radio. The diode can short, and this will cause the blown fuse. If you check the fuse and find it's black again, you should check the diode with an ohmmeter. Look for the diode near where the battery lead connects to the circuit board in the radio.
Aug 02, 2011 | Uniden Solara - VHF Marine 2-Way Radio
Will a 750 inverter run a sump pump off of a deep cycle marine battery for a short period of time?
Looking at this, how many amps does the pump normally draw? Take this and multiply by 3 for start up current draw. Now, multiply that by 120 (volts) and this will give you the watts. Start up current is what will knock your inverter down. It won't kill the inverter but it will overload it on startup and turn off the unit. Since I do not know the size of your pump, this is my caution. You could always try it, the most that should happen is that the inverter will shut down.
Feb 05, 2011 | Black & Decker Husky 750w Power Inverter
I just bought a 74 lb Minn Kota trolling motor that is 24 volt. It is used and has 4 wires (2 black & 2 red) coming from rolling motor. Can you please tell me how the wiring is connected to the...
I have uploaded a image of the wire system. folllow it carefully. the fuses rating should be no more than than thirty amp. go to your local outboard dealer they sell inline breakers that are designed for trolling motors. i prefer them because you don't have to replace them after a overload. you just reset the breaker.de79e02.jpg
Oct 29, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
I am trying to wire and bridge a sony marine 600w sony marine amp
as long as the speakers are wired in parallel it should be ok dont wire them in series as they will overload the amp it is designed to run at 4 ohms
Feb 13, 2009 | Sony XM-2150GSX Car Audio Amplifier
Volvo Penta Marine engine 5.0 GXI 2004
there should be some loose connection or short circut, that is the only thing that can cause it.
Sep 23, 2008 | 2004 Volvo V50
I have an Amana bottom freezer fridge model ARB2517CSR the freezer stopped working I cleaned the coils and the fan was working and the fridge was making a buzzing sound. The sound stopped, so did the...
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
Jul 03, 2008 | Stainless Cruise 49 Marine Refridgerator -...
Electrical Supplies Logo
19 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
