Question about Home
I have a leaking Magna series HydroAir LD7 bath pump that leaks when running. Can I tighten something or just replace the pump bc of faulty seal?
  • 68 Answers
SOURCE: jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
Posted on Dec 11, 2008
Maytag317
  • 1136 Answers
SOURCE: Kenmore 90 series washer is leaking water from the pump. How do I remove the pump to repair or replace? Thanks!
Hi, You can change the pump by disconnecting power, water fill hoses, & take drain hose out od drain. Lay the washer on its back (use some padding under machine so that you do not damage threads on inlet valve. The pump is located on motor and has two clamps holding it. Just remove those clamps and the two drain hoses from the pump. The pump should release from the motor shaft. If the motor shaft is rusty, the pump might not want to come off ease and the shaft will need to be cleaned with sand paper or emery cloth so the new pump will go on easy. Failure to get the pump on all the way will cause the new pump to leak also.
Put your hoses back on the pump and everything should be ok.
I hope this helps you some.
Vic
Posted on May 10, 2009
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Posted on Jun 12, 2009
  • 27 Answers
SOURCE: leak between seal plate and pump/strainer housing
The pump seal is leaking and needs replacing and requires removing four 3/8 bolts (9/16) wrench and removing the motor then the diffuser to get to the impeller and seal . A 7/16 wrench holds the rear motor shaft behind the springs and impeller spins off to reveal the seal which has two parts one on the impeller with a spring and one in the seal plate is white ceramic/ porcelan whatever they use. Part number is an SPX1600KA on super pumps and 1500KA wassome above grounds. When replacing do not touch the mating white and black surfaces with your fingers.
Posted on Jul 20, 2009
SOURCE: oil leak problem with 1996 toyota camry
I am going to see a mechanic - my trusted mechanic who does not nickel and dime me - to see what this is. I have the same problem and he told me he has never done this job on a Camry and is unsure. Given the miles, he has suggested that maybe it is time to part ways with the car. I am going to ask him if he will put some florescent dye in it and let me drive it for 50-100 mi and then check to see where the leak is and fix it. Let you know what happens. I have to try, the car is solid.
Posted on Aug 15, 2009
Model number LD 5MC-C
The pump you are looking for is not made anymore. The Air Switch version is still available.
You will need the replacement pump, an air button and some air tubing
to make the new system work for you.
You can find this and bathpartsplus,com under their bath pump section.
US Parts Center
Jul 02, 2014 | Balboa HydroAir Magna Series Spa Eyeball...
Tip
How to troubleshoot water leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Check the lid seal. If faulty, replace with a new gasket.
- Check the hoses at faucet connections. Tighten connections or replace hoses.
- Check the hoses at water valve connections. Tighten connections or replace hoses.
- Check the drain hoses. Tighten connections or replace hoses.
- Check the inlet nozzles. Tighten connections or replace nozzles.
- Check the splash guard. Tighten connections or replace.
- Check any plastic valve. Tighten connections or replace.
- Check the outlet hose to drain. Tighten connections or replace hose.
- Check the water pump, using the procedures that follow.
on Jan 16, 2010 | Washing Machines
Just purchased a used Dream Maker X400 hot tub. It holds the water during the filtration cycles but if we attempt to use the hot tub by turning on the jets there is a major leak. Is this from one of the...
Have you opened the equipment access door and looked in it while it is running. I would look at the pumps to see if one of the seals are leaking. They will leak more on high speed and if you have a cir pump that runs the filter and an additional pump for high speed jet action it would make sense why it is leaking more while you are using it.
Oct 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a HydroAir Magna Series Whirlpool pump model #LD7AC that will not shut off with the airswitch. The airswitch does not appear to be disconnected nor does the tubing appear to be clogged. Any...
If your bath pump LD7A-C will not shut off when you push the air button then the AIR SWITCH in the motor needs to be replaced.
This is a pretty common problem with Bath Pumps and easily fixed.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Home
Hydroair magna series whirlpool pump model #LD7AC airswitch does not work. It appears to be connected properly and not blocked. Any suggestions?
If your Bath Pump will not shut off when you push the Air Button, it sounds as if the Air Switch is not working in your Bath Pump.
Click on the Air Switch name and it will show you the replacement part you need to fix the Bath Pump.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Balboa HydroAir Magna Series Spa Eyeball...
Water leaking from pump
Hi thomasgor192...
If you have water leaking from the pump then you have a faulty seal that must be replaced or a gasket leak or failure.
Turn on your pump, bring it up to pressure and try to locate the leak with a flashlight and then you may be able to repair your problem by replacing your seal or tightening your gasket or replacing it.
Please take time to rate me
Jul 03, 2011 | Home
Old admiral clothes washer leaks at front
Troubleshooting Water Leaks
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 25, 2009 | Maytag PAV2300 Top Load Washer
Oil leak from oil pump
steam clean engine first ,run engine and then look for it .before you start spending money on something that might just need a tighten
Nov 21, 2008 | 1997 Toyota Land Cruiser
Jacuzzi bath
Good Luck, Phil
Oct 06, 2008 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Home Logo
41 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
