Question about RCA RS2664 Shelf System
Rca rs2664 tuner trouble
Rca rs2664 CD not playing
Hello
The laser pickup unit of your device is faulty. It should be replaced with same type and number.
Jan 25, 2012 | RCA RS2664 Shelf System
RCA RS2664 Stereo
Do you know by any chance if a CD might be stuck inside?
Does the device power up?
Apr 09, 2008 | RCA RS2664 Shelf System
Cant listen to radio & getting an open error 255
The mistake that throws you is that it has fault in the tuner of radio oi also it can be that not esten programmed the issuers
May 31, 2011 | RCA RS2664 Shelf System
I have a RCA brand home stereo system. Model number RS2664. Recently, the big speakers (the bass reflex subs) quit working. And I plugged them into the smaller speaker Jack, and they work fine. The...
The sub-woofer amplifier is probably blown. This is a separate circuit from the other channels. It will need to be repaired. It is likely a bad transistor or open resistor that over heated.
Nov 09, 2010 | RCA RS2664 Shelf System
My RCA RS2664 won't stay on. As soon as I power on, it says "bye" end turns back off. Help Please!
This is a common problem with this model.  There is something wrong with the power circuit.  Open this puppy up and test the circuits.
Your first mistake was buying a RCA you cheap ***.  Get you a Sony, Panasonic, or Pioneer.  Less stress and more fun.
Take the thing back for a refund if your within 30 days.  Have RCA tech support fix it if your within 1 year. Pawn this thing off on e-bay or a garage sale or Goodwill if your out of warranty.
Oct 26, 2009 | RCA RS2664 Shelf System
Open err 255
are u sure its not the code
Jul 23, 2009 | RCA RS2664 Shelf System
Not able to record onto or play from mp3
cheak format out put in its menu ok make suree on mp3 128 bit rate try that what player uusing if its ipod then no use i tunes in windows for that ok
Jan 23, 2008 | RCA RS2664 Shelf System
Open error 255
pls check supply voltage to tuner circuit,since this is digital tuner check digital clock and data.if you dont have scope to check,may be you try with vom meter and check about 4.7v on both line.when you select tuner notice slight flicker on your metre which will give hint of clock and data present.
Dec 16, 2007 | RCA RS2664 Shelf System
RCA RS2664 Shelf System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
