How to enter service mode bizhub 421 - Office Equipment & Supplies
2 Suggested Answers
fawazkhalil0
  • 5 Answers
SOURCE: how to enter service mode on bizhub 164, pls inbox me the seervice manual if you have it at teetop42yahoo.com. thanks in anticipation.
How to enter service mode on bizhub 164 + bizhub 215
Posted on Feb 09, 2013
HOW WOULD I RESET ANY CODE IN MY BIZHUB 420
SOLUTION: To clear the message:
1. Enter Service Mode.
2. Select [System 1].
3. Select [Initialization].
4. Select [Counter Data].
5. Select [Fixing Counter].
6. Press the Start button.
7. Exit the Service Mode.
Oct 26, 2017 | In Office Equipment & Supplies
Bizhub 421 light copy result
Take out the toner cartridge and tap it on it's end to dislodge any packed up toner first. If this doesn't work and a new toner cartridge has no effect, then the high voltage applied to the drum is not attracting the toner powder. That will take a repair service to fix the printer.
Jun 10, 2015 | Konica Minolta Bizhub 421 Mfp...
I have installed an brand new bizhub c 364 machine, now it gives me security lines either blue or red , can anyone help me in solving the problem ,thankyou
Install was done incorrectly,
CAUSE: Initial settings did not take when programmed.
SOLUTION: Time and date, telephone and ADF serial numbers need to be reentered:
1. Sub-power ON g Utility/Counter g Machine Admin settings g System settings g Date and time setting g (Enter year/month/day/time) g OK g Exit g Power OFF sub-power switch.
2. Enter Service Mode g System settings g Setup date input g (Enter year/month/day) g OK.
CAUTION: DO NOT POWER OFF. Leave machine in Service Mode.
3. In the Service Mode g System settings g Telephone setting g (Enter 16-digit number) g OK. Repeat for the fax number. Set to all 9s if there is no fax number.
4. In the Service Mode g System settings g M/C serial number setting g touch ADF g (Enter ADF serial number) g OK g Power OFF sub-switch.
5. Power ON sub-switch and run copies with no security lines.
May 27, 2015 | Konica Minolta Bizhub C364 Color Copier /...
Service mode bizhub 421
Utility/Counter
Meter Count
stop 00 stop 01
Jan 30, 2014 | Konica Minolta Office Equipment & Supplies
Bizhub 421 driver
IF YOUR USING A BIZHUB 421 DRIVER FOR A MAGICOLOR 2550, THAT ITS YOUR PROBLEM YOU NEED TO GO TO
onyxweb.mykonicaminolta.com/OneStopProductSupport?appMode=Public
SELLECT MAGICOLOLOR PRINTERS 2550
WHEN EVER I TRY TO PUT THE FULL LINK, IT WONT LET ME POST, BUT I YOU PROBABLY KNOW WHAT TO PUT ON THE FRONT OF THE LINK
Aug 21, 2013 | Konica Minolta magicolor 2550 DN Laser...
Minolta bizhub 421
Kindly tell me what is the problem you are facing in Konica Minolta bizhub 421 MFP?
May 30, 2012 | Konica Minolta Bizhub 421 Mfp...
Bizhub c252 how do you reset enter serial number
NOTE
• When Main-power was turned ON while the Serial No. was not entered (including
initial status), the message to require entering the Serial No. will be displayed.
Make sure to enter the Serial No. at setup. sound like some did not follow the set procedure. go to service mode and enter the machine serial make a mistake machine will be out of commission
Mar 09, 2012 | Konica Minolta bizhub C250 All-In-One...
Konica minolta bizhub 200 c2557. Help please!
c-2557= ATDC Sensor abnormality to reset go to service mode, to enter service mode perform these steps, 1-press utility/counter button from the panel, 2-press check details, and press "STOP" 0,0, STOP 0,1 3-now you are in service mode, 4-click on tech rep mode,or Adjustment 5-now click on "Printer" 6-here increase the value, suppose you have 150, make it 170, press the clear button to clear it and enter new value which should be more than the previous one. press enter and exit from the service mode.
Jan 14, 2010 | Konica Minolta Bizhub-200 Minolta Printer
Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Feb 08, 2008 | HP Officejet 9110 All-In-One InkJet...
69 people viewed this question
k24674
jasbo
jasbo
