Question about Eureka The Boss Upright Vacuum Cleaner
Install belt pt.#52100A on Eureka "The Boss" Model 2034 Type R
Change a belt on a Hoover S2220 Cleaner
Hi there! Unfortunately, the belt on the S2220 can not be replaced. If you need further assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil. Thanks!
Oct 18, 2014 | Hoover Flair Broom Vac Air Outlet Filter...
Replacement Parts
Sorry we do not have parts here or parts books,.
Jul 06, 2017 | Electrolux Eureka Optima 437AZ Lightweight...
Bearing on brush is hard to turn and smells like it's burning
bearing hard to move will put strain on the belt and burn it. the bearing is easily removable pull it off, sometimes its just a good clean it will need, if will not come off tape it off. remove the muck build up and give the bearing a good soak in some wd40 or oil and wipe off and check for good movement then replace the belt. as it will snap more easy now it has been heated up.
Mar 15, 2014 | Eureka The Boss Upright Vacuum Cleaner
The piece on the bottom of the vacumn that controls rug height will not work
I had to use pliars to change the level. I only used that vac three times and I got rid of it. It cut off on me and never restarted. Sorry!!
Mar 05, 2014 | Eureka AirSpeed Bagless Upright Vacuum,...
Eureka abs AS1050 will not power on?
There is a wire in the motor housing that comes loose plug it back up and it should start
Nov 30, 2013 | Eureka AS1104A Bagless Upright Pet Vacuum...
My eureka vacuum stopped working.
Need more information. Does the motor run, does the brush turn, does it have suction?
Aug 03, 2013 | Eureka 4870 Boss SmartVac Upright Vacuum -...
Oreck Air 12GU Instruction Manual
First of all, thank you very much Joe for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.oreck.com/PUG/Air-ProshieldPlus-AIR12GU-userguide.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Jan 31, 2012 | Oreck XL Professional Air Purifier
Clean light won't go off
Evil little critter, huh? Find the sensor and clean it.. Seems it is the boss onn that unit.. Good Luck, Ned
Sep 16, 2009 | Air Purifiers
Eureka The Boss Upright Vacuum Cleaner Logo
51 people viewed this question
Top Eureka Air Purifiers Experts
Are you an Eureka Air Purifier Expert? Answer questions, earn points and help others
