Question about Car Audio & Video
Sound car amplifier
My amplifier have noise with the engine how i arrange it pls thx
  • 47 Answers
This could be couple of reasons
no.1
check that you havent run the rca's down same side as power lead as this causes a whining sound
no.2
Check your earthing point make sure its suitable
no.3
Check your auternator maybe faulty
there is a easy solution to this and thats to by a rca ground loop isolator which filters out unwanted noises
heres one i found on ebay for £5 click here
Posted on Apr 23, 2009
I have a yamaha THR 10 guitar amp and I am using the 8 alkaline batteries to power it instead of pluging it in to the power inverter of my truck. I am a truck driver and got this amp because I want to play...
If it was electrical noise you could get a suppressor just like you would for a car engine. But it sounds to me that you are saying it's amplifying the actual sound of the engine. If this is the case there's not a lot you can do. As the amp is designed to amplify the noise of a guitar, which is noise in general, not an electrical signal. At least that's how understand how guitar amps work. Though I will stand corrected if I am wrong!
May 27, 2017 | Yamaha Audio Players & Recorders
Hi I'm Wayne. Pls help me with my GA13DS engine
Check for a bad rocker arm and correct valve adjustment. Make sure cam timing is correct. Never try to retard or advance the cam timing.
May 16, 2017 | Cars & Trucks
1.sounds making noise that comes along with the engine tune? 2.my mono amplifier got burned during installation, is this possible for repair?
keep the rca cords away from your power wires( +) and the remote lead. The rca cords have a tendency to pick up and reproduce alternator noise if you run them too close together. Generally you should run them on opposite sides of the car when wiring. hope that helps.
Dec 11, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Why the amplifier is getting the sound of the engine att he spekers? while having the car with the engine running, you can clearly hear the engine noise on the speakers
There could be a number of issues
1. Grounding
2. Kinda speaker cables your using
Check your wireing and make sure this is not grounded to where it can be interfered by the engine.
Aug 17, 2010 | Majestic MA4200R Car Audio Amplifier
I have a lanser 4000 outputting loud engine noise
Double check your connections. Sounds like you are picking up alternator whine. Make sure the rca cable is at least 12" away from power and remote cables when installing fem radio towards amp. Its best to runthem on opposite sides.
.A thumbs up would be greatly appreciated if this answer is helpful to you. lanser-4000-outputting-loud-engine-noise-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jul 17, 2010 | Lanzar MXA282 Car Audio Amplifier
High pitched squeal from Bose car stereo
Have you or your dealer tried an inline noise reducer? It worked on my truck. Worth a shot. Good luck!
Feb 02, 2010 | Car Audio & Video
Sound car
the problem u are havin is interferance.
make sure your rca's are run separate from the power lead, then check that you have a good earthing point and if you still get your problem then get your auternator looked at.
You can buy a ground loop isolator witch is around £5 this will filter out these noises
Hope this helps if so please rate :)
Apr 23, 2009 | Car Audio & Video
A Buzzing noise from my Reverb section of the amplifier
i am sensing 60 cycle hum. the reverb will draw more power. i would try what is actually powering the units. power strip??? off of an unknown amperage power outlet? if the electrical system that feeds the a/c outlet is ran in series, you may not be getting enough juice or the outlets have bad grounds. i dont see a capacitor causing the buzz noise, but more of a pop and then sudden loss of signal. may be a resistor. also if you have a reverb tank the lines maybe mixed up in/out, or the tank is going bad.
Nov 16, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Need wiring diagram to put Pioneer DEH-385OMP into a Nissan Pathfinder
Perhaps below wiring arrangement may be of help.
Pls be reminded that on most Nissan Pathfinders, there is an amplifier connected to the original stereo.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Car Audio & Video
Jensen Amplifier..4 x 50WRMS at 4 Ohms
This sounds like you need a ceramic noise suppression filter/ferrule on the Power line to the amp. You should be able to get a suitable one from most car audio shops. Hope this helps, please post again if you have trouble getting one :)
Mar 28, 2007 | Jensen A600HLX Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
