Question about ASI TPL SWT TLSG1008D 8PT Gigabit
Hi i have a tl-sg1008d switch. this switch has 8 ports and seems like i can only have 2 active connection at once only. can you help? fibre connection > modem > to port 1 on switch pc 1 connected to port 2 on switch wireless router connected to port 3 on switch pc 2 connected to port 4 on switch only my pc 1 and wireless router can be connected. pc 2 can only connect when i disconnect pc 1.
4 Suggested Answers
jimbo6
  • 89 Answers
SOURCE: wireless connection
Where did it go? Any errors or just doesn't show up in tray? Has it been disabled in Network Neighborhood?
Posted on Jan 10, 2008
SOURCE: wireless laptop
THANK YOU
Posted on Apr 14, 2008
puertobori
  • 7733 Answers
SOURCE: If I connect TP-LINK TL-WR1043ND
If your OS is Windows there is a good tutorial at -> Working with Widows Wireless Networks
That can help you out to configure your wireless networks.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Jan 17, 2011
I cant seems to be able forward ports on my TP-Link WR841N Router to view my cameras remotely. Pls can somebody help me with a solution. what should i do?
First, you need to know what's IP of Router and your Camera (or DVR). Then browse to IP of Router and setting up NAT port (or port redirect. If cannot you can give me your Skype, I will help you more then here.
Jun 06, 2015 | TP-Link Technologies TP-Link TL-WR841N...
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
or
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
May 03, 2017 | TP-LINK TL-SF 1008 P 8-port 10/100 PoE...
We have two computers and we can t connect at the same time
You must make sure your ISP- Internet Service Provider allows more then one conection.
Shut everything off for 2 minutes the start everything up 1 at a time giving time for full boot up of each in between each devicethis can often fix the problem but often you will need a router rather than a switch as a switch does not assign IP addresses so it will look as though both PC's have the same IP address and booting one or the other ofline.
If this is helpful please give it a Thumbs Up!!!
Good Luck!!!
Jun 13, 2011 | TP-LINK TL-SF1008D 8-Port Ethernet Switch
I HAVE 30 TP LINK (TL-SF1008D) SWITCHES ATTACH WITH MY SERVER .IF ANY SWITCH WILL OFF OR DEAD HOW CAN I FIND THEM THAT WHICH SWITCH HAVE PROBLEM. IS THERE ANY SOFTWERE TO GET ALL SWICTHS MAC ADDRESSES OR...
A switch should not have bad ports, its just a basic level device not much higher than a hub. Make sure you are using straight through cables to connect pc's to it. you can tell if it is a straight through most of the time by looking at the colors from left to right. (see picture) this will not be the case 99% of the time but sometimes a switch or router will come with one for connecting to other switches (which is what crossovers are made to do.
nathan_f.gifNote the colors and check to see that both cables have the same. if one is different then it is a crossover (it crosses wires so that similar devices can connect together.) Hope this helps, good luck with your switch.
May 08, 2011 | TP-LINK TL-SF1008D 8-Port Ethernet Switch
How to connect netgear fs108 to cable modem
leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
How to link with 16 port switch with 8 port switch
Good question.
To link the new switch, take a short cable from the LAN port on the new Switch and connect it to one of the existing ports on the old or connected switch. it's just a daisychain.
Just keep in mind that the LAN connection on the Last switch must be connected to a PORT on the prior device on the LAN.
Apr 03, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Connecting a 3Com 2952 Plus switch to a Cisco 3750 switch
If you also have a standard copper cable (or a second fibre cable) connecting the two switches (for resilience perhaps?), this issue is probably being caused by something called Spanning Tree. This is implemented on switches as a 'loop avoidance' system, and can look like you have described with one end 'ip' and the other end no lights.
On the Cisco switch, get to a telnet/ssh/console session, log in and enter show spanning-tree and press enter.
have a look to see if the fibre interface has a status (sts column) of BLK. If it has, then this is called 'blocking' and will remain like that until you remove the second link to the other switch.
Hope that this has helped!
Mar 03, 2010 | 3Com 3CSFP91 Transceiver
Hi i need a KVM extention over fiber solutions please
You will probably find that all fibre kvms are expensive.
Quite often you will find it cheaper to purchase some other pc's and a fibre switch to run them back to the rest of the net or server.
Aug 14, 2009 | Avocent DSR1021 (DSR1021AM) 8-port KVM...
ASI TPL SWT TLSG1008D 8PT Gigabit Logo
Top ASI Computers & Internet Experts
 Russ Hill
Russ Hill
Are you an ASI Computer and Internet Expert? Answer questions, earn points and help others
