Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Can I refill the original ink cartridges on my HP Officejet Pro 7500 Series Regards Dontacho
  • dontacho Apr 23, 2009
    Can anyone tell me where the battery is on the HP Officejet Pro 7500 Series
    Thank you very much for the helpful information. Do I need to change the chip for this to work?
    Regards
    dontacho
    Scholar:
  • 154 Answers
Step 1) Put the cartridge on some paper towels in an area where you can tolerate a spill such as a sink. Be sure that you are wearing old clothes, since the first time you fill the cartridge, you will probably get some ink on your clothes and hands. You may wish to wear rubber gloves if you don't want to stain your hands. I also don't recommend refilling as a family project. Step 2) Look at the cartridge. Near the bottom of the cartridge you will see a horizontal break line in the plastic where the two parts of the cartridge snap together. Step 3) Using a sharp knife or scissor blade, cut the label on the front of the cartridge along the line where the two parts of the cartridge come together. Step 4) Using a knife,screwdriver, or just your hands pry the cartridge open along the line. Let it hang by the backside label. Step 5) The exit port is the point where the ink comes out of the cartridge. It has an obvious stem. Place this stem to your right. Step 6) You will also see a rubber oval-shaped bulb. To the left of this bulb is the fill hole. You will see a small ball in this hole. Stick a pin or the end of a sharp knife into this ball and pry or lift it out of the hole. (Saundra recommends a sharp steak knife. (*** Don't stab or cut yourself!***) Don't lose the ball! Step 7) Fill your syringe bottle with the appropriate ink. You'll need about 30 ml (1 full syringe bottle) for the regular cartridges, about 75 ml (2 1/2 syringe bottles) for the high capacity black cartridge. Step 8) Insert the needle 1/4 to 1/2 inch (5-10mm) into the fill hole. Be careful not to puncture the bag, especially if you have a sharp needle. Step 9) Inject the ink into the opening. Step 10) Tilt the bag so that the opening is at the top. This will let the air bubble up and out. Step 11) Using the syringe, suction about 1 ml (1/4 teaspoon) of ink and air frothy mixture out of the top of the bag. Step 12) Inspect the ball. If it has been damaged, you should use a new ball or the damage may cause a slight leak. (We have additional balls for sale.) Step 13) Replace the ball in the cartridge. Saundra says, "The tip of a retracted ball-point pen is ideal for this." Step 14) Turn the cartridge upside down (stem down) and gently squeeze to check for leaks.
If you see a leak there are three possible problems.
1. The bag inside the cartridge has bursted or is punctured. There is no fix for this: the cartridge is dead.
2. While refilling you allowed ink to escape and get on the white collar surrounding the exit port, bulb and fill hole. The ink has now leaked between the bag and the sides of the cartridge. Even though this is usually only a small amount of ink it will act like you poured an entire pint in there! The solution is to remove the bag. Please do this over the sink. As you are looking at the cartridge you will notice that the sides are long ovals. Hook your thumbs inside the ovals and pull as if though you are going to pull the cartridge apart. You will see two plastic tabs. Release one and then the other. Using the bulb frame as a gripping point, pull straight up and lift the bag. This will be messy. Rinse the outside of the bag and the inside of the cartridge shell. Try not to get water on the copper chip while you are working. Using an old towel or a paper towel, dry off the bag and dry out the inside of the cartridge.
3. You have not pushed the ball into the hole securely. Push it in again and wipe up the excess ink. Squeeze the cartridge to make sure you have it sealed tightly before putting it back in the printer.
If there are no leaks insert your cartridge into the printer and print.
The light on your printer warning you that the ink is low will remain ON. This is normal. Do not panic: just see if it prints
Posted on Apr 23, 2009
I bought all new cartridges, inserted them the way they were removed, but message board still says defected cartridges. how to install ink properly and make error message disappear?
Here is a video from HP explaining the process. IF you followed this procedure and are getting errors, then you may have bigger issues. I am assuming you are using genuine HP ink, not remanufactured or refilled cartridges.
Replacing Cartridges for HP Officejet Pro 8600 All in One Printer Series...
Aug 31, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
How do I correct my problem with black vertical lines on my officejet 8600 printer?
Try cleaning the print heads using your HP maitenence program of by going into your printers section of the start menu.
Sep 23, 2014 | HP Officejet Pro 8600 Plus e-All-in-One -...
How to disassemble
Power on printer and soak up spilled ink with towels. Next we suggest you remove PRINTHEAD from printer and inspect for damage to contact pin(s) on the INSIDE OF THE PRINTHEAD ASSEMBLY. Please refer to printhead removal procedure below for reference (HP Officejet PRO 8600 Printhead Removal & Replacement Procedure):
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c02871867
NOTE: To gain access to the service menus and advance printer reset procedures (and service tests) for the HP Officejet Pro 8600, 8610, 8620 or 8630 series printers please refer to our HP Diagnostics document at the following link:
Advanced HP Printer Diagnostics (i.e. printer self tests, etc.): http://inkjet411.com/?page_id=1813
Please note that if you choose to refill your ink cartridges with Costco/Frys, etc., the refill comes with a new chip so the ink level monitoring will be reset and function like a brand new HP OEM ink cartridge. We provide professional HP 950/951 ink cartridge refilling services in multiple countries and at multiple retail outlets:
INK REFILL SERVICES:
Costco USA (462 stores): http://www.costcoinkjetrefill.com
Costco Canada (57 stores, more coming soon): http://www.ca.costcoinkjetrefill.com
Costco Mexico (35 stores): http://es.costcoinkjetrefill.com/
Fry's Electronics (34 stores): http://www.frys.com/ads/page51
Best Buy Canada (13 stores): www.geeksquad.ca/inkrefill/
Micro Center (8 stores): http://www.microcenter.com/site/content/refill-service.aspx
9 Major Universities in USA & Canada
Ink Cartridge Refill Store Map Locator: http://www.go2ris.com/
Our network of retailers stand behind the product and performance - guaranteed. Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at INKJET411HELP@GMAIL.COM
Alternatively, if you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20.
-Thank you
Aug 08, 2014 | HP Officejet Pro 8600 Plus e-All-in-One -...
Refilled ink cartrige still showing empty is their any way to reset printer
Regarding your HP Officjet Pro 8600 printer and refilled HP 950/951 ink cartridges and the "low ink" messages. Depending on your ink refiller (or if you did it yourself?), a replacement chip may or may not have been installed with the recently refilled cartridge(s). Refer to picture on our support site to first determine which type of cartridge configuration you have, then refer to the applicable section to address the current cartridge error(s) or printer issues.
http://inkjet411.com/?page_id=1999
NOTE: Costco USA's Ink Refill service now 'chips' all refilled ink cartridges which fully restores all functions to that of a regular HP (OEM) ink cartridge and customer experience. For USA ink refill store locations and details on ink refill pricing:
Costco USA Ink Refill Service (all 453+ stores): http://www.costcoinkjetrefill.com
Fry's Electronics Ink Refill Service (all 34 stores): http://www.frys.com/ads/page51
Micro Center Ink Refill Service: http://www.microcenter.com/site/content/refill-service.aspx
Refer to Section A if your refiller attached a new replacement chip (green in color) onto the cartridge. Refer to Section B if only the original HP chip is attached.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures (due to incompatible ink formulations). We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested! HP original/genuine ink cartridges can be identified by the visible HP logo on the front label of the cartridge.
HP 950/951 Ink Refilling & Additional Cautions:
http://www.youtube.com/watch?v=zOCC3h0OFiI
Questions regarding the use of refilled ink cartridges: http://www.inkjet411.com
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Mar 31, 2014 | HP Hewlett Packard Officejet Pro 8600...
I refilled HP 8500 cartridge but printer (Officejet Pro still thinks cartridge is empty. How do I reset ink level?
This model printer may only let you use genuine printer cartridges. If you try to refill these ink cartridges it will not work because the cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Mar 03, 2013 | HP Officejet Pro 8500 All-in-one -...
My officejet pro 8600 will not accept thick paper to print on
Use upper tray , not the main tray for thick paper, see for setting in upper tray.....
Oct 11, 2012 | HP Officejet Pro 8600 Plus E-all-in-on...
How to reset ink levels on HP Officejet Pro 8600 Premium
shut of both the electrecity and the shut bottom press 10 minutes than replugg and start
Apr 16, 2012 | HP Officejet Pro 8600 Premium e-All-in-One...
I refilled HP 88 cartridge but printer (Officejet Pro L7590) still thinks cartridge is empty. How do I reset ink level?
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
Nov 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Feb 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
150 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
