My lexmark x 342n says 202.13 paper jam open rear door. We have done that and it still says that.
SOURCE: Lexmark X73 print/paper problem
Same problem here. Went thru a few tests with Lexmark but didnt help. They next said it would be best to get new one since repair cost would be higher. Thru front door I do see a spring that moves freely. That must be broke. After their help they sent email for 20% off.
Posted on Sep 13, 2007
SOURCE: Canon MP830 paper jam
Your "Best Solution" posted 10/01/07 needs just a little bit more. I followed the directions and saw the jammed paper but couldn't get hold of it. I then called Canon support and they told me that the green plastic can be pulled up and then the paper under it is accessible. I pulled up the green plastic and was able to grab the jammed paper and pull it out. He also told me that the solution could be found in the Canon knowledgebase with a color picture as well.
Posted on Feb 04, 2008
  • 4 Answers
SOURCE: 202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Posted on Aug 08, 2008
rcw1962
  • 2571 Answers
SOURCE: 202 Paper Jam, but there
Thank you very much! ????
I am not sure where you think you are posting, but to leave a comment like that is unlikely to get a favorable response.
This is an independant help site, this site has nothing to do with Lexmark, and so the thank you very much comment is unneeded, and unwelcome.
You may have paper stuck inside the machine, where you cant see it, If you had a jam, and pulled the parer out, some may have stuck inside, or you may have damaged something pulling it out.
You may have to take the printer apart to check
Posted on Sep 16, 2010
  • 86 Answers
SOURCE: hi, my lexmark T640 is saying 202.06 paper jam,
This jam is refering to back door, jam in fuser (hot bit) Double check no paper is wraped around fuser rollers.
These machines have a fuser at rear if you look at he fuser from the back, on it you will see, two thick fuser rollers (ones rubber), paper runs threw these then it hits a little black switch (your machine thinks this switch is activated) and then a series(3,4) of small rubber exit rollers, this switch (between middle and left) can get damaged it also likely that a piece of paper is concertinaed in fuser.
Posted on Oct 20, 2010
Printer says paper jam open rear door There is no paper jamming in the rear
This issue may have been caused by a fuser problem and the rear door assembly. Please try to contact Lexmark's technical support center.
Jun 20, 2011 | Lexmark X342n All-In-One Laser Printer
Paper jams in roller
If the paper jam is inside the printer, open the printer cover and access the paper jam. Firmly grasp the paper, and then gently pull it out. Be careful not to tear the paper while removing it.
If paper jam is in the Automatic Document Feeder (ADF), open the ADF door, and then gently pull out the jammed paper. Close the ADF door. Touch DONE. From your computer, resume the print job.
Jun 08, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
We had a paper jam in the front of printer but now the printer is saying 202paper jam open rear door. We have done this several times. I do not see any paper jamming the printer anywhere. We have shut off...
Please click on the link provided below. This will show you steps on how to correct the error. http://bitly.com/r09NH8 For further assistance please contact Lexmark Technical Support Center.
Feb 14, 2011 | Lexmark T430 Laser Printer
Hi, my lexmark T640 is saying 202.06 paper jam, check rear door. i have opened it and there is no jam, there is no paper anywhere and have pulled all the trays out and there is no jam. what do you suggest?
Oct 20, 2010 | Lexmark T640 Laser Printer
Rear door paper jam
Here are some articles on rear door paper jam on Lexmark X646e printer. Just click on these links: http://bit.ly/blkK1m ("202 Paper Jam" Message on a Lexmark X642e, X642e or X644e Multifunction Printer) and this link: http://bit.ly/awNDER (A 202.xx (x = any number) Paper Jam Message Is Appearing on a Lexmark X64x Series Printer). These are some guidelines on how to resolve the rear door paper jam on your printer. If you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jul 22, 2010 | Lexmark X646e All-In-One Laser Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
How do you open the rear door of the C510 to clear a paper jam?
Hi I hope you have this solved already... but you just grab the edges and pull from the top sides. It feels really weird, but it will be fine.
Mar 30, 2009 | Lexmark C510 Laser Printer
Light error
You should contact Service Center regarding this.
Jul 25, 2008 | Lexmark E232 Laser Printer
202 pam jam
Jun 13, 2008 | Lexmark T630 Laser Printer
54 people viewed this question
k24674
jasbo
jasbo
