I have a Whirlpool washer Model number wfw9050xw00. I have had nothing but problems it is about 2 years old. Last night it wouldn't do it's finale spin, I unplugged it for about 20 min than tried it again. i have checked the pump to see if there was something in there it was empty, So when I got home to day I pulled the washer out and put the hose down in a bucket thinking maybe all the water isn't draining well there was no water so i put the washer back and the hose back and now it won't do anything i ran the diagnostic on it and i get one time the washer light blinks 6 times then 1... So i unplugged the washer again and tried to run a full cycle and now the washer light blinks 3 times then 1... I'm so I don't know what else to try. and i can't find out what these error codes mean
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
  • 958 Answers
SOURCE: Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Had this problem on our Kenmore machine.
This is what done.
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
Posted on Jan 11, 2009
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
  • 662 Answers
SOURCE: Error 03 not draining or going to spin cycle. Tub
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Pl rate me ‘very helpful’ for the free help!
Posted on Jun 15, 2010
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
My 2 year old Whirlpool washer does not work ...with power on I get no indicator lights ...it just hums and acts like the drum is trying to move ...nothing working ...I can have lid open and it still hums...
you did not give model number, but on some you can unplug washer then hold down power button while plugging it back into power and that will reset the control panel. worth trying. good luck.
Mar 03, 2015 | Whirlpool Washing Machines
I have a Whirlpool washer WFW9050XW00 that stops during the wash cycle. The machine beeps and the wash light flashes 8 times pauses and flashes 1 more time. Thank you in advance
http://www.repairclinic.com/Shop-For-Parts/a11b5d875741/Model-WFW9050XW00-Whirlpool-Washing-Machine-Parts >Go to the website provided and you can check some troubleshooting options. If your issue isn't addressed there click on repair help or Live Chat Now for free assistance. The Google search showed this site and said live help is free. Hope this helps.
Jan 06, 2015 | Whirlpool Washing Machines
My Kenmore Oasis HE is about 4-5 years old. Withing the last 6 months or so, it has started faulting to UL(uneven load) in the final spin cycle every load. It doesn't matter if I am only washing 1...
Sears has a recall for the Kenmore Oasis washer. I have the exact same problem. Call Recall Line @ 1-800-659-7026 with Model number and serial number. The part is a control board that works with the spin cycle.
Feb 25, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool washer will not spin
sounds like the timer is shot.
Apr 30, 2009 | Whirlpool Washing Machines
I can't find the model number on washer Whirlpool Ultimate Care
Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
Dec 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Elite gas dryer
Hello.
vegetarianGA
You said,
When I purchased my house 2 years ago, the sellers left the washer and dryer for me. They informed me of a problem with the dryer's start button not wanting to stay pressed in. They said their solutions was to use something to keep it pressed in and so I started using shipping tape for this purpose. Last night it finally stopped working - something behind the button is obviously broken (the switch). While looking for a replacement switch and an on-line service manual, I came across this site. I did order the part from Sears today and will attempt to repair the problem myself. If I cannot, I will buy a new dryer before I pay a tech $60+ to repair a 6 year-old dryer.
I did not have the model number when I called Sears but did have another number off the back of the dryer which was for the "panel control" and the number is 3979018. The sales rep did some cross-referencing and said I own model #11072932100. I was wondering if you can direct me to an on-line service manual so I will know how to replace the switch when it arrives.
Here our sponsor's site to fine what you asked me for, a service manual!
www.Manual.Pronto.com
You sound like you are right on target !
Bless You, Huuum
Please leave me a good rating before you sign off.
Thank You
Sep 05, 2008 | Kenmore Elite HE4 Electric Dryer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
