Question about Brother DCP 115C All-In-One InkJet Printer
Pc does not see the printer all usb ports on the board are working fine what is the problem
When connecting the usb cable the pc does not see the printer "DCP-115c brother printer" The problem started after re formatting my pc and trying to re - install the software
  • pmsefoka Apr 23, 2009
    I did install the drivers then it asks me to connect the printer and switch it on for the installation to continue but nothing happens after the it just freezes
    New Friend:
  • 113 Answers
First install the Drivers for your printer in your PC and then connect it via usb cable. Hope your problem will be solved.
Posted on Apr 23, 2009
  • Achabacha
    Achabacha Apr 23, 2009
    Try Uninstalling your previous installations. Then try a fresh installation again.
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Network port not working, it does not even blink when Ethernet cable is inserted, it does fine with usb cable
On board network port faulty, badly no recovery & no add on card facility for this printer. Use through USB, or else replace Formatter board.
Mar 18, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
My usb port on monitor isn't working. how can i fix this?
The USB ports on the monitor will work only if you connect the monitor via a USB cable to your PC/Laptop's USB port. Sounds awkward. Doesn't it? There must be a USB cable with flat socket on one end and trapezium shape jack on one end. It should be in the box which the monitor came in. The USB ports in the monitor are just another extended USB ports for your PC/Laptop. If you can't find the cable mentioned above, it is the same cable you connect to a printer, scanner,........ In some cases you might need to install a driver which should also come along with monitor. Mostly you don't need to install.
Good luck.
Apr 13, 2012 | NEC MultiSync 1770NX 17" LCD Monitor
After loading the system shows error 'cannot recognize usb port'
According to your problem, first make sure that the USB port of your system is OK and working fine. Connect another plug and play USB device to this port or move to another USB port. Check that you have connected the USB cable properly. You can reinstall the driver and reboot the printer and the system both by follow the instruction of printer installation manual. Check the USB cable of the printer or replace the cable. It will help you.
Jun 10, 2011 | Canon LASER SHOT LBP-2900 Printer
My dell 924 printer has stopped working. I get an error message that there is no USB connection. All connections & USB cable are fine. For some reason this printer is no longer on a USB port - have...
Hello.
It sounds like a issue with the hardware inside the printer. if possible try the printer on another PC, or try another USB Cable. Sometimes the cable can appear fine but can have small breaks inside it. You can also try your current cable on another persons printer to rule out the cable.
If you can not get the printer working on another persons computer I would suggest replacing it. it is cheaper than getting a tech to fix it.
Regards GM
May 27, 2011 | Dell 924 All-in-One InkJet Printer
HP Printer Usb port in my Acer Laptop , shortcircuits my house
hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Aug 26, 2009 | Acer Aspire 6930-6941 Notebook
Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
HP laserjet 2200D connected via USB gives problem
try plugging into another usb & reinstall the driver that may help.
Jan 16, 2009 | HP LaserJet 2200D Printer
Connecting my Brother MFC 440cn printer to the internet
It turns out my dad had the usb cable plugged into the ethernet port instead of the usb port. It works fine now.
Thanks for the response.
Oct 26, 2008 | Computers & Internet
Printer is not being recognized by the system
problem with usb connector in logic board of printer.please check the continuty of four tracks of usb cable to board.
Sep 27, 2008 | HP LaserJet 1018 Printer
Brother DCP 115C All-In-One InkJet Printer Logo
110 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
