Question about Magic Chef CER3725AA Electric Kitchen Range
Magic Chef electric range model # 3888VRA
Just bought this range used, so I don't have and owners manuel. A buzzer came on and where the clock is F-1 appeared. I can push the stop button and it goes off for a little while, but it comes back on. The range is not even in use.
  • helpa Nov 02, 2007
    magic chef range mode # 38HA-6TVW-EV. I too bought this second hand from a lady whi said it works great! Nope, the top burners work fine but I cannot get the oven to stay on. It will warm briefly and just stop. F1 will start flashing and beeping. Pusing the stop button stop the beep but only for about 20 seconds. The clock works fine. If it is the control panel or as some call it the brains, is the part available and easy to install?
  • Anonymous Mar 26, 2014
    door wont open pushed button does nothin
I have the same problem...beeps when breaker is turned back on. I need a manual. Any suggestions appreciated. Oven, everything works fine.
Posted on Dec 28, 2007
  • 473 Answers
Sounds like the oven control needs to be replaced.
Posted on Oct 06, 2007
SOURCE:
Our Magic Chef oven just began making a whirring noise and the clock stopped functioning properly at the same time.
Hi Peggy Freeman,
I suppose that it is a Maytag Magic Chef.
From your description my conclusion is an electrical fault on the clock.
You have to open the cooker and remove the connection to the clock.
BE CAREFULLY
Always insulate the connector, as it is mains grid.
When it is indeed the clok, the noise will stop, but you an not use the clock anymore.
Kind regards, Dik
Here you find a PDF of the Maytag Magic Chef:
https://www.repairclinic.com/UserManual/b8e1b97795884ea59496a9eaf1a93883/Magic-Chef-Range-Stove-Oven-Repair-Manual-CGL1100ADQ-CGL1100ADW-CLL1101ADW.pdf
Feb 08, 2018 | Kitchen Ranges
I have a buzzer that goes off then on the control panel by the clock it says F1.Ihave to unplug it for it to go away but it comes back on
Hi curlyf112000,
F1 error description is a defective touch pad or clock (ERC). To resolve this error, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Oct 28, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef Oven 3888VRA beeps and shows F-1.
Hi this is indicating a Defective touch pad or clock (ERC).
This simple test will help determine whether the ERC (Electronic Range Control board or Clock) or the touch pad is defective when F1 error code is present. Follow carefully, and with caution.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: Do not preform this test if you feel as if you are not qualified to do so. Contact your local service depot, if needed.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 17, 2009 | Magic Chef CER3725AA Electric Kitchen...
My mom has a Magic Chef oven, model 5892VRV. It
You have 2 choices.
Replace the electronic control(clock).
Or, replace the range.(stove).
Sep 04, 2009 | Magic Chef Ovens
REPLACEMENT COST OF MAGIC CHEF ELECTRIC RANGE MODEL 6898XVB
you should be able to buy one for between 400 to 600 dollars new.i would check lowes or home depot to see what they have in stock.
Jan 13, 2009 | Magic Chef CES3760 Electric Kitchen Range
Manuels
here is pretty good link for the product.it might just serve useful.
click here for manual and other info.
good luck.will wait for your comments.
sunny
Jan 09, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef range
f1 is the code for a failed clock most of the times you must replace the clock most of them have a five year warrenty check your owners manuel for warrenty info
Mar 12, 2008 | Cooktops
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Nov 18, 2007 | Maytag MGR5751AD Gas Kitchen Range
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic Chef CER3725AA Electric Kitchen Range Logo
245 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
