Question about Nitro BMW-482 Car Audio Amplifier
Nitro 1000w bmw-483 4ch bridgeable amp wireing hookup
  • 631 Answers
SOURCE: Nirto bmw-486 Tech Specs
Generally, this type of amp is relatively simple to repair if you're capable of replacing the blown parts. If you can find the web site for Nitro, you may be able to get a schematic. I couldn't find their site.
What troubleshooting have you done?
What parts are blown?
If you need help troubleshooting, I'd need a photo of the inside of the amplifier.
babin_perry@yahoo.com
Posted on Jan 14, 2008
JULIANFIX
  • 975 Answers
SOURCE: Nitro BMW 1000w amp not working
if AMP turns on and no sound , check the inernal fuses that protect the output from overload , in most cases this fuses act like a cicuit breaker , they set back on again in a few seconds. hope this helps
Posted on Apr 29, 2008
  • 113 Answers
SOURCE: I have a Nitro BMW-483 AMP
if you still get sound it just might be the led
Posted on Jul 05, 2009
  • 242 Answers
SOURCE: my nitrobmw-486 amp keeps overheating
head gasket has gone
Posted on Dec 27, 2009
Shorty1_wt
  • 324 Answers
SOURCE: my nitro bmw-486 amp is in protect mode how can I
protect mode is activated either because of a short in a speaker wire or because of excessive line voltage like the volume being too loud. atleast that the most common reasons that I have experienced.
Posted on Feb 24, 2010
How do I connect my nitro 1000 watt amp to get thr most bass .i have two 15 vx kickers
If you have the Nitro bmw-482 running it at 2 ohms will give you the max output (its not 1ohm stable so don't run it that way). First run your two dvc speakers parallel (run both negative out puts together and both positive out puts together on each speaker). After this you should have 1 positive and 1 negative wire from each speaker (4 wires altogehter). This will give you a 1 ohm load which your amp can't handle, so you have to run the 4 wires in series to create a 2 ohm load. Now take the positive wire from 1 speaker and connect it to the negative wire from the opposite speaker. Thats how to run in series. Now you should have 1 positive wire from 1 speaker and 1 negative wire from the other speaker which is 2 ohm load. Your amp sould be bridgeable, so connect the positive wire into the correct terminal of your amp and the negative wire into the correct terminal of your amp according to where to bridge it (positive into left positive, negative into right negative) . That will give you a 2 ohm load bridged which is the most power you can get out of your amp 300 watts. Medium quality amps are over rated so you will never acheive the 1000 watts as advertised.
Dec 01, 2011 | Car Audio & Video
Nitro 483 amp where do you hook up the power it has a gnd rmt and +12v what hooks up where
Fused 12 volt power wire from the battery connects to +12V at the amp. Chassis ground wire connects to gnd at the amp. Switched 12 volt power wire (accessory) (remote turn on from after market radio) connects to rmt at the amp.
Jan 18, 2011 | Nitro BMW-483 Car Amp
It Will not turn on
maybe ur need a capacitor cuz ur prob over loading ur power supply
Feb 22, 2010 | DHD NTX-2004 Car Audio Amplifier
Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
Jan 25, 2010 | Rockford Fosgate Car Audio & Video
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Nitro BMW 484 1200 watt amp.
check fuses and remote wire at the head unit. must have a good ground at amp.
Dec 03, 2008 | Nitro BMW-482 Car Audio Amplifier
Need wiring diagram for bmw-483 1000w 4 channel amp bought used
left + goes to the amp left - goes to the + on the right sub and the right - goes to the amp try that
rate pls
Nov 18, 2008 | Nitro BMW-482 Car Audio Amplifier
Apr 28, 2008 | Nitro BMW-481 Car Audio Amplifier
Install diagram?
i dont know where to find the instructions, but it shouldn't be all that difficult. I used to have one of these legacy amps .....what hookups do you have on it?
Mar 15, 2008 | Legacy 4CH 1000W RED AMP Car Audio...
Jan 14, 2008 | Nitro BMW-486 Car Audio Amplifier
Nitro BMW-482 Car Audio Amplifier Logo
82 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
