Question about Samsung Cell Phones
Samsung model #p51d450a2d turn's on red led flash makes noise nothing happens
SOURCE: E4 Error It blinks all led flashing E 4 after making a jam noise, then turns off after a while
It seems your printer,s carriage is jam or carriage encorder is out of carriage sensor
Posted on Nov 08, 2008
SOURCE: my samsung p2 desnt turn on it only flashes the
try reseting your device by pressing the small hole on the back of the device that has the small letters RES under it.
Posted on Aug 16, 2009
  • 178 Answers
SOURCE: SAMSUNG TXS3082WHX/XAA Won't Turn On
All of these tv's are board replacement only the individual parts are not available. The boards can cost anywhere form $200 - $400 each. Even if you do it yourself it is still an expense, if you get the blink code i can point you to the correct board. These sets have different boards even within the same model range. One of the first diagnostics is does the back light come on, if not then you either have a balancer error or a bad bulb in the panel. Why i suggest this is because it is the most common problem. If it is the bulb in the panel you have to replace the whole panel, the bulbs are not available as an individual part.
Posted on Sep 02, 2009
  • 610 Answers
SOURCE: my samsung LE40M8 lcd tv won't turn on it just
sounds like a bad power supply board.
Posted on Nov 02, 2009
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
Samsung PS51D550C1M plasma tv loads Samsung page and turns off, LED flashes 4 times and repeats process again? The led flickers when the remote is used but nothing happens? Thanks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Mar 02, 2016 | Samsung Televison & Video
Blank screen, led lights flashes for a while and thn all three flash. also cannot turn off at tv or with remote. have to unplug
Samsung HL67A750A1F red DLP LED failure repair ...
? 10:35
https://www.youtube.com/watch?v=xHE1knzJSfQ
Jul 21, 2011 - Uploaded by daveshelbygt
Samsung PHLA... ... Samsung HL67A750A1F red DLP LED failure repair .... tv only works when plugged in. black screen, any suggestions?.
HL67A750A1F Blank Screen, And The LED Lights Are On ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsFeb 24, 2011 - Click here if the screen is blank and one or more of the LED lights on the front of the TV are on or are flashing.
Samsung HL67A750A1FXZA Repair Success Stories ...
Jan 19, 2016 | Samsung HL67A750 67 in. TV
Samsung n150 wont turn on just led light on at nothing appear on screen
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 20, 2012 | Samsung N150 Netbook
I have just bought a Wharfedale ICS182 in-car radio but it doesn't seem to work. The red light that indicates power works but nothing is happening. Please help.
Take the control panel off.
Turn ignition off.
The alarm led should flash slowly.
Turn ignition on
The alam led should flash quickly.
If it stops flashing, take the radio out and get it repaired/replaced under warranty.
Dec 28, 2010 | Car Audio & Video
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Tv switched on nothing happens apart from red led flashing on front of tv help no picture or anything
Need to know the model number and also how many times is the led flashing in between pauses as the blinks are indicating an error code, But cant help without the model number and knowing how many blinks its blinking.
May 17, 2008 | Philips Televison & Video
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
