Question about Kodak Cameras
Lense not coming out, please help cant afford loosing it
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Video is choppy and cant afford getting fix from canon store....is it the head, the lense?
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Mar 19, 2011 | Canon GL1 Mini DV Digital Camcorder
My canon g9 was on the lense extended and from then on it will not turn on again
The Canon G9 has a design defect, two screws fall out inside the camera and short out the fuse. If you've never had it fixed for no power before this is most likely what has happened to your camera.
Do a Google search for "canon g9 no power repair" and you will see a full repair service including return shipping of your camera for just $85.
Hope this helps!
Thomas
Owner, Darntoothysam.com Digital Camera Repair
Feb 13, 2011 | Canon PowerShot G9 Digital Camera
I have a 1992 for explorer sport and cant get the front passenger seatbelt to come out. its stuck all the way in. ive tried to pull it out and it wont come it wont even budge a little. ive looked at the...
The plastic cover should be able to be removed. There is a ratchet mechanism for the seat belt, after removing the cover, you maybe able to free it up to get the belt loose, some WD-40 may help.
Apr 28, 2010 | 1992 Ford Explorer
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Sony cyber shot dsc-n2
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Problem with lens
if you cant afford it read this,
The reason for this is that I find it easiest to track a moving subject if it's in the middle of the viewfinder. Cameras cannot know what you want to focus on, and if you start using multiple AF points, how is the camera supposed to know that you want to focus on the bird and not the tree - cameras are lacking in human thought processes! What is quite handy though is using the AI SERVO FOCUS or AI FOCUS settings so that the lens will alter it's focus on the subject over which the centre AF point is aligned as it moves towards you or further away from you. Without this, the focus will fix at the point you half depress shutter and if the subject comes closer or goes further away then it will be out of focus. you can call any expert of lences also for it if you can afford.
May 22, 2008 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
Fujifinepix F30
Maybe it the connector inside is loose, you might try to open the case (a 5 euro triblade / triwing screwdriver is needed) and see if any of the connectors is loose, before sending it for a 160 euro repair.
Nov 21, 2007 | Fuji FinePix F30 Digital Camera
Cameras Logo
50 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
