Question about Denon CDR-M30 CD Recorder
Balance control - Denon CDR-M30 CD Recorder
How to adjust balance control on Marantz sr66 receiver?
As you rotate the control, you should feel a "notch" at dead center where left and right speakers are balanced. If channels are not balanced, you will have to rotate the control either left or right of center.
Apr 29, 2017 | Marantz Audio Players & Recorders
The volume level is low and schachy on one side of balance, most noticed in low volume, once the volume is increased greatly the balance comes back. if left in low volume the balance control on the bad...
Hello,sounds as if its an older reciever and the control is simply dirty(dusty) . What i would recommend (if you can access it) is simply spraying contact cleaner into the control .Contact cleaner can be purchased at a radio shack or online ,just get a quick drying one and do it while its unplugged.
Feb 14, 2011 | Audio Players & Recorders
Which running shoe models are best for Plantar Fascia Problems?
wore the Brooks Adrenaline for athletic walking to help my foot with plantar fasciitis. The American Academy of Podiatric Sports Medicine recommends that you get the proper shoe for the kind of motion control you need to correct overpronation or oversupination and that the shoes has good cushioning to help control trauma to the foot.
Some models they recommend with extreme motion control include:
New Balance 1123
Asics Gel-Foundation 7 WSC or Evolution 3
Brooks Beas
Saucony ProGrid Stabil
Models with moderate motion control include:
Brooks Adrenaline GTS 8
New Balance 90
Ecco RXP 1660
Mizuno Wave Alchemy 7 WSC
Light motion control models include:
New Balance 1010 / W / S
Asics GT-2130
Mizuno Wave Nexus 2
Saucony ProGrid Echelon Score - 35
Oct 27, 2010 | Clothing Accessories
Harmonic balancer bad car runs real bad
The harmonic balancer controls the triggering of the combined crankshaft/camshaft sensor. This controls ignition plus fuel injection. Replace the balancer and adjust the sensor or replace it if damaged.
Oct 18, 2009 | 1998 Pontiac Bonneville
Wheel vibrations at 75+ mph
Most computer controlled tire balancing machines which are in use today only balance tires to between 65/70 miles an hour. To get them balanced to a higher speed you might want to call a few auto performance shops and see if they balance tires to a higher speed. At higher speeds it takes very little in the way of an off balanced tire to really set up a vibration so shake.
bigc
Jun 11, 2009 | 2003 Honda Odyssey
Speaker left/right balance control
This Aiwa audio system has no balance control as its already balanced.
May 19, 2009 | Aiwa NSX-AJ20 CD Shelf System
Is there a balance control on this radio or is that fixed???
Hello kayriecken,
You did not specify whether you have the old classic Becker or the new retro. I'm pretty sure that the knobs were "spring loaded" on my old '60's Becker (actually in a 1971 Mercedes 280S - later replaced with a Blaupunkt). On mine, you just pulled out lightly on the knob and it switched function to balance. One side, the volume controlled left to right balance, and the other side, tuning, controlled front to rear balance (fader). Try it and see if it works.
Hope this helps.
May 04, 2009 | Car Audio & Video
Want to use two wii fit boards at the same time?
You can't sync 2 balance boards to one wii.
I heard this is why but this isnt confirmed...
the wii can only register 4 controllers at one time... the wiifit balance board counts as 2 controllers, leaving only 2 controllers available... obviously a person would want at least one regular controller to use along with the wiifit balance board, so just using wiifit leaves only one free controller slot available...
hope this helps...
Feb 05, 2009 | Nintendo Wii Fit for Wii
Acer speakers desktop
***For Windows XP***
  • Click on start > Control Panel > Sounds and Devices
  • The Window Below will appear :
  • Click on the Advance button and the volume options will appear
  • Adjust the balance on the master volume (Just Drag arrow to the middle)
***For Windows Vista***
  • Click on Start> Control Panel>Sound
  • Click / Highlight the speaker then click on Properties
  • Click on Levels tab
  • Click on Balance
  • Adjust Balance
Nov 03, 2008 | Acer Aspire (AST180-US340B) PC Desktop
Ob error, out of balance?
may be bad basket drive ..main control detects out of balance by currect draw on motor had a basket drive cause same sympton .. after replaceing control bds and motor changed basket drive and solved problem
Jun 05, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Denon CDR-M30 CD Recorder Logo
14 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
