Question about Cisco RV220W WLS-N NTWK SEC FW - RV220W-A-K9-NA Router
Cisco rv220w dont know password - Cisco RV220W WLS-N NTWK SEC FW - RV220W-A-K9-NA Router
How can I download purchased items on itunes (error 8003) from behind a Cisco RV220w firewall?
Configure the Cisco to "log everything", and then try the iTunes download. Then, examine the log-files, to see which connections were blocked. Then, configure the firewall to "allow" those TCP-ports.
Apr 23, 2014 | Cisco RV220W RV220W-A-K9-NA Wireless...
Tip
Guide to Reset Password on a Cisco Router
How do I reset the password on my Cisco router?<br />I bought a Cisco 1700 router from an auction, but there is a password. How can I reset the router to original factory specifications? <br /><br />Sky sagem wireless router reset password? I just got this sky wireless router second hand and it has a password set on it. i tried to press the reset button at the back but it does not do any thing, it still comes as a password is set.<br /><br />How to reset password on dlink wireless router? I have a dlink wireless router model number DIR 825 . It works good but I am trying to access internet on my ipod and the password i have set is incorrect , this also happened when i tried to access internet on my laptop. When i first set up my ps3 i dont recall having to put a password in but this was when i first got the router. How do i reset the router password or find out what the password is AND if i reset the password or reset my router will my ps3 have to be reconnected or will it stay?<br /><br />How to reset password on a router? I recently acquired a linksys router (used) and need to know how to reset the password so that I can use it. Also, is there any way to modify a router to be useful as a cell/wifi blocker, or as a signal booster?<br />... <br /> ----From Yahoo Answers<br /><br /><br />To reset password on a Cisco/D-link/Linksys/Netgear router is a very common problem among people who want a secure network environment for surfing on the internet. If you are confused with the complicated procedure to reset or change the password on a router, or if you are trying to configure a Cisco router, but a password is blocking you from enable mode, don't worry, just do the steps as follows, password reset on a router is no longer upset to everyone.<br /><br />First, be informed that what you need:<br />.<a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router</a><br />.Computer<br />.Internet Connection<br />.Blue Serial Cable<br /><br />Guide for You to Reset Password on a Cisco Router:<br />1. Download a program called Putty from the first resource site below. PuTTy is a terminal emulator application which can act as a client for the SSH, Telnet, rlogin, and raw TCP computing protocols (PuTTy on Wikipedia).http://en.wikipedia.org/wiki/PuTTY<br /><br />2. Connect one end of the blue serial cable to the Cisco Router and the other to your computer. Open up the Putty program on your computer and select the radio button next to "serial" on the right-hand side of the start window. Click on the "Open" button in the bottom right-hand corner of the Putty start window to open the terminal.<br /><br />3. Power the Cisco Router on. As soon as the router begins loading in the green and black Putty terminal window, press the "Ctrl" and "Break" keys simultaneously until its going into rommon mode.<br /><br /><br />4. Once in rommon mode, you have to change the configuration register number to make the router boot from a blank configuration file. For the 2800 series Cisco Routers, the command "confreq 0x2142", changing the register number to 2142, worked. Search on cisco.com for information on your particular <a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router Series</a>.<br /><br />5. Type the restart command in rommon mode, which is "reset". This will boot the router up again. When it is finished, you should be able to type "en" to get into enable mode without a password.<br /><br />6. Once you change the running-config in RAM and save it to the startup-config in NVRAM, remember to change the configuration register number back to its default (usually 0x2102). This is important if you change anything on the running-config. <br /><br />Easy five steps help you finish resetting password on a Cisco router. Easy instruction, easy to follow. <br /><br />
on Jul 19, 2011 | Computers & Internet
Where do you get cisco connect
Cisco connect is the software that comes with the router.
You might have installed the Cisco connect software while installing your router for the first time.
Once you open the Cisco connect software for E1000, you will find the password to access the wireless network.
If you have not installed Cisco connect then you can open the setup page of the router and check the wireless settings.
Dec 17, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
I WANT TO CHANGE MY PASS WORD ON MY LINKSYS E2500
access the ipadd of your linksys then thats the time you can change your password. if you dont know the password then its time you reset your router and reconfigure it again.
Aug 25, 2011 | Linksys By Cisco E2500 DualBand WirelessN...
Default username & password after hard reset
Username:[none]
Password:Cisco or
:root
:Cisco or
:Cisco
:Cisco
Try from above 3 then you can access cisco router.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 01, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
I have a router cisco and I dont remember the passowrd
Are you a Cisco Router user and forgot its password? Well, there are several ways to reset, change and recover Cisco Router password. But, for an instant solution, you must take the professionals help by calling them up at their Cisco support number. You can get this phone number from Contactforhelp, a trusted online directory famous for customer support and services.
Jan 22, 2010 | Gateway Wireless-B Router (wbr-100)
I just got an itouch and when i went to access the internet, it told me to enter a password to access belkin54g. so i went on the belkin default page on my computer and i successfully logged in and i dont...
go to the address bar in the internet explorer type there 1292.168.2.1then enter it then ask the user name and password
user name :cisco or admin or blank
password : cisco or admin or blank or password
try this combination then go to the wireless in the security option is there in that wireless password is there as encryption like that in the wep or wpa or wpa2/psk like the option is there then change it
Jun 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Default pasword
Cisco switches dont have a default password.
You will have to perform a password recovery process that is quite extensive.
You need to console into the switch using hyperterminal or teraterm and follow these instructions located at: http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Dec 13, 2008 | Cisco Rf Catalyst 2960 24-PORT 10/10
Cisco router 857
Hi Anthony-
The default username is "cisco" and the default password is "cisco" as well.
Nov 30, 2008 | Computers & Internet
Cisco RV220W WLS-N NTWK SEC FW - RV220W-A-K9-NA Router Logo
57 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
