Question about Toro Garden
How to install the needle valve in a carburetor of a toro 524 model 38040 2 stage snowblower
    Master:
  • 755 Answers
Take bowl of the bottom of carb pull out little pin that holds float bowl on change needle valve put back together make sure you put the bowl gasket on right or it will leak
Posted on Jan 20, 2015
Toro snowblower surges what could be wrong? Any help will be appreciated. Thanks
Try removing the needle from the carburetor and soaking it in brake fluid (and any other parts that may look suspicious) over night; clean and regap or replace spark plug; ...also, try using high test fuel.... this runs cleaner on my Toro826.
Jan 06, 2018 | Toro Garden
Only runs for a short time
Jeff, Try running with cap off for a short time to see if cap vents plugged, probable dirty carburetor.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Snowblower Starts Then Stalls
Tecumseh Carb snowblower cleaning 1 of 2
HOW TO Remove Clean Fixed JET on Snowblower Carburetor
Mar 23, 2016 | Toro 1028OXE Power Max 38663 2-stage...
Snowblower won't start
"Gone thru Carburetor" Did you check the Needle valve Seat? The ethanol gas ruins the seat if they are made of rubber and the needle valve is all metal.
Does the Float actually move up and down as it's supposed to? sometimes the ethanol gas absorbs too much moisture and the needle valve or pivot point of the float rusts.
Mar 01, 2015 | Toro Power Clear 418 ZR - Single Stage...
How do I clean carburetor
check out this YouTube video for cleaning a single stage snowblower carb.
http://www.youtube.com/watch?v=KYj5oH0vNVg
Dec 15, 2013 | Toro Power Clear Snowblower 418ZR - 38272
I was given a Toro 521 Snowblower. It won't start. I replaced the plug, gas filter, air filter and gas line. Still won't start. Also drained the tank and added new gas
If you replace the carburetor needle seat and bowl gasket it will do the trick. Look up your model snowblower at www.arcolawn.com and you can have them shipped.
Good luck
joe
Feb 14, 2011 | Garden
I have a Toro 524 with Tecumseh engine, model 38040 8 0000640. I am rebuilding the carb and would like to know what are basic settings for idle and hi/low speed screws?
The high speed mixture screw is initially set at 1 & 1/2 turns out. Then adjust it to give good acceleration and top speed, while not closing the screw more than you need to. The low speed mixture screw is set at 3/4 of a turn out. Adjust that, to give a smooth idle. The 3rd screw, the idle speed screw, is set to give a low idle speed without stalling.
Jan 14, 2011 | Toro Blowers Rake and Vac - Electric...
Garden Logo
271 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
