Question about Sony KDL40EX500 40 in. HD-Ready TV
Sony KDL40EX500 power supply. Board has standby power but other voltages don't come up. Tried shorting "Power On" pin (pin 13) to "STDBY3.3V (pin 15) to try and get the board to power up but nothing.
  • 1 more comment
  • Coen Willemse
    Coen Willemse Oct 12, 2013
    Oh - sorry, I should mention the fact that if everything is assembled and tv plugged in, the standby LED (Red) lights. When the tv is switched on, the "TV ON" light turns on (i.e. green LED). No other voltages present on the PSU board however.
  • Coen Willemse
    Any help would be greatly appreciated! :)
  • Coen Willemse
    Hi - thanks for your help!Have been through the PSU with a fine tooth comb, checked all the MOSFETS, rectifier, diodes etc which all look fine. I was mixed up about the "Power Good" line though - apparently this is the PSU's signal to the connected boards that voltages are stable and they're "good to go". Anyway, thinking of replacing the caps next as the main primary power cap seems to have a slight bulge coming out of the top...
    Problem Solver:
  • 19 Answers
If You do not see any open link or resistor, short IC or transistor on power supply it must be a control board problem. You must get the set to SONY, as it is necessary to exchange board and upgrade software.
Posted on Oct 12, 2013
Testimonial: "Opps - this was supposed to go down here... Hi - firstly, thanks for your help! Have been through the PSU with a fine tooth comb, checked all the MOSFETS, rectifier, diodes etc which all look fine. I was mixed up about the "Power Good" line though - apparently this is the PSU's signal to the connected boards that voltages are stable and they're "good to go". Anyway, thinking of replacing the caps next as the main primary power cap seems to have a slight bulge coming out of the top... And if that doesn't fix it, you're probably right - it could be the control board... Which would be a real bummer...."
  • 20 Answers
SOURCE: sony PFM-42B1E plazma screen
Does the red standby light flash ?? If so count the flashes and see my error code section.
Posted on Aug 25, 2008
  • 12 Answers
SOURCE: My Sony KDL-32M3000 has dark
It will be either BM board (Video Processor board) or Tcon Board (top side of panel). I have similar problem...my TV turns on, lamps turns on (you can see them from back side panel holes) but just a dark blue picture appears with no image (like picture when external input is selected without signal), no OSD appears....some times I can heard audio (using Antena).
I'm thinking getting the BM board.
Posted on Jan 10, 2011
alpug
  • 1961 Answers
SOURCE: I have a 2007 32" Sony Bravia KLV_32U300A with an
sometimes defective capacitors are not noticeable visually unless we use an capacitance tester/instrument .better replace the capacitors at the secondary of the transformer and resolder the pc board .check also the connectors make sure that it fits the socket tight..good luck
let me hear if you have further question..
Posted on Feb 07, 2011
  • 8909 Answers
SOURCE: Sony Bravia KDL-40S3000...standby red light blinks
There may be no horizontal ouput, Check C515 & 516 and the jungle IC, IC206.
Hope that helps
Posted on Feb 28, 2011
  • 17 Answers
SOURCE: Sony Bravia LCD KLV-32U300A Symptoms: ~ powering
I know its a 32 inch TVand its probably about 2 years old, give or take. If you got a warranty on it, I suggest calling whoever you got it from (BestBuy,Amazon, etc) and seeing what they can do for you to get it fixed for free. Otherwise call Sony abotu getting a real tech out to either fix or swap parts on the TV at your house, or where to send it for repair. Depending on what it costs, you are probably better off buying a new 32inch LCD TV for about $400.
It seems you have isolated it down to the power supply though. If you are confident enough, you can get a replacement on ebay for abotu $100.
Just depends on what you value more: time or money.
Posted on May 21, 2011
Vizio M422i-B1 TV won't turn on. Opened up and checked power supply board but the pins for the 5 volt standby power aren't connected to the cable. How else can I verify the power board is not bad?
You should have 5V on pins 15 and 16 of connector CN9100 of the power supply. If you are not getting any voltages on the connector, the power supply board is bad.
May 19, 2017 | Vizio Televison & Video
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
My Sony Bravia HX8/46 will not turn on, I check all the power going to it and it all works. Is there something I can do?
Is the standby led on the front lit. If not likely the problem is with power supply. If the standby led is on does it go off when the power button is pressed? Does the led blink. If so count the blinks and get back. The power supply provides an standby voltage to the main board. If the standby led is lit then this voltage is present. When the power button is pressed the micro sends a turn on voltage to the power board. Normally the power supply will respond and all other voltages needed to operate the set will come up. if a component is shorted the micro will not turn on the power board and will usually give a failure code via the standby led.
May 31, 2013 | Televison & Video
Sony KDL52XBR4 will not power up
Some power supplies have a short circuit protection. it turn off the power supply if it detect an overload/short condition.
Mar 08, 2013 | Computers & Internet
Kdl-40w3000, when power button pushed, tv comes on for a few seconds then shuts off then standby blinking light comes on 13 blinks, pause,13 blinks pause, etc
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise,
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this will to fix the fault......
May 29, 2011 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
PC with ECS P4VMM2 V5.0A motherboard won't power up after working for years. Power supply fan doesn't come on, case fan doesn't come on, PC dead. Tried replacing power supply, same result. Power supply...
The mother board and the fan also need replacement. If you have recently added any other hard ware to the machine, remove it and try booting again.
Apr 11, 2011 | Computers & Internet
I want to convert this power supply for use with a battery charger for model aircraft. I need to know the color codes for the wires and also the pinout and which wire is the power on.
Pin Name Color Description
3 COM Black Ground
4 5V Red +5 VDC
5 COM Black Ground
6 5V Red +5 VDC
7 COM Black Ground
8 PWR_OK Gray Power Ok (is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation)
9 5VSB Purple +5 VDC Standby Voltage (max 10mA)
11 3.3V Orange +3.3 VDC
12 -12V Blue -12 VDC
13 COM Black Ground
14 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
15 COM Black Ground
16 COM Black Ground
17 COM Black Ground
18 -5V White -5 VDC
19 5V Red +5 VDC
20 5V Red +5 VDC
18 AWG is recommended for all wires except pin 11, which should be 22 AWG. For 300W configurations 16 AWG is recommended.
There are several ATX variants.
Hope this helps.
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me as well. Thank you.
Nov 26, 2010 | Compaq (243890-001) 250-Watt Power Supply
Sony KDL40EX500 shuts down and flashes a red LED 7 times. What does this mean?
This is a issue with the power supply board here is a link that shows you what this blinking light codes mean
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
Sep 03, 2010 | Sony KDL40EX500 40 in. HD-Ready TV
I tried several different cards but no luck. Cards work ok on other computers.
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
[JP-25]
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
May 09, 2009 | Computers & Internet
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
Sony KDL40EX500 40 in. HD-Ready TV Logo
218 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
