Fluffy go walkies leg is stuck - Office Equipment & Supplies
How to clean my fluffies?
Just follow these steps:
STEP 1: Soak you Dirty Fluffies
STEP 2: Wash them on a regular setting, in cold or warm water in washing machine.
STEP 3: Brush out your Fluffy
STEP 4: Hang your fluffies up to air dry.
STEP 5: Once your fluffies are nice and dry, you'll have to brush them out one more time to really bring them back to 100%.
STEP 6: Enjoy Your like-new FLUFFIES!
For more details about any Rave outfits, you can visit:
Rave Clothing and Festival Fashion RaveReady
Jan 11, 2017 | Washing Machines
I NEED SOLUTION MY E2222 IS SIM 2 IS SHOWING INSERT SIM
This happened often in the early days of mobile phones and usually the problem was solved by removing the sim and cleaning the contacts and sometimes cleaning the receptacle contacts too. Most people gave the sim a brisk rub on a trouser leg but that is not very wise as the sim contains sensitive cmos technology that is super-sensitive to static discharge until it is installed. In the absence of a non-fluffy cloth moistened with a safe cleaning solvent a clean pencil eraser is suitable.
If cleaning doesn't help try fitting a known good sim...
Nov 07, 2016 | Cell Phones
Uniden gmr2638_2ck is always stuck on receive. Rd is always showing and static coming from the speaker
Adjust your SQUELCH control or setting so that the noise disappears. The RX indicator will go out.
Mar 01, 2015 | Uniden Radio Communications
Tripod leg stuck
loosen the allen head screw for that legs snap lock
Mar 13, 2013 | Manfrotto (190XB,128RC) Tripod
Leg stuck on Manfrotto 732CY tripod
Other than the leg locks themselves, sometimes Manfrotto expands the last portion of the leg tube that slides into the leg tube above it. If you need some spare parts you can find them here.
www.bogentripodparts.com
bogen and manfrotto are the same company
Nov 07, 2012 | Manfrotto Bogen 732CY M-Y Carbon Fiber...
I have a motorola cp 110 walki talkie .red light comes on but no beep or commuunication
If you have no initialization beep when you turn the radio on, it is likely the radio is in need of repair. Immediate things which come to mind are a sticking PTT button, something stuck in audio accessory jack, or a bad speaker. You might check the radio using a second radio and see if you can transmit.
best regards.
Nov 08, 2011 | Motorola Walkie Talkie 2-Way Radio
Playing games it gets very hot and turns off. only had 3 days
It is important to remember that laptops draw in air from the bottom of the unit. So if you place the laptop on your bed or a nice fluffy pillow on your lap to keep your legs from getting hot, then it can't draw in air and it will over heat. The second thing to remember is that, while they are good laptops, Acers are generally not the best for gaming and the internal graphics card may be getting over worked.
Aug 26, 2010 | Acer Computers & Internet
My motorola xtr446 has an icon stuck on it and no one else can hear me when i speak out? how do i get rid of the icon? the icon is a mini walkie talkie
The mini walkie talkie emblem has a variety of meanings. If the emblem has parenthese around it your PTT (push to talk) button is depressed, stuck or partially depressed. If the emblem does not have parenthese your radio is in receive mode, awaiting a call.
It is possible you do not have your radio programmed identical to the other radio(s). Your frequency and interference code eliminator must be identical to those used in the other radios. Here is a link to the manual where you can check this http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103 Look around page 7 for instructions.
Also, if you find your radios are programmed identically, the other problem might be bad or low batteries, as it takes more energy to transmit than to receive.
Best regards.
May 15, 2010 | Motorola Walkie Talkie 2-Way Radio
Phone not displaying anything except when plugged in
Your phone is stucked...sometimes the walkie might be the cause...try removing the battery and switch on it again
Aug 14, 2008 | Motorola Mobility V360 Cellular Phone
k24674
