Question about 13 HP Electric Start GX390
Fly wheel wont release to start it Honda gx390 . the I can get to release and then it does it again
  • 46 Answers
I think you're talking about the pull starting cord? It wont release when you pull it out and it pulls itself back in. They sell a kit to replace that part. Just keep track of your bolts and screws when you take off the housing to get to the part.
Posted on May 25, 2015
Calve gap on a Honda GX390 engine? Hi, I have a gas power washer with a Honda GX390 engine in it. I need to adjust the valves. Any idea what the gaps are supposed to be? Also do I adjust on a cold engine...
Hi intake is 0.15+ or - 0.02mm and exhaust is 0.20 + or- 0.02mm cold engine..I always double check after running the engine again...you can check out the owners and service manual and all specs here http://cdn.powerequipment.honda.com/engines/pdf/manuals/37Z5F602.pdf
Feb 23, 2015 | Honda Garden
I installed a new GX 390 Honda engine in a Toro 413 TX machine. Motor starts, idles and full throttle fine, but when hydraulics,i.e. drive is engaged, motor dies.
you have a dingo, ugh
I would suspect a bad pump or wheel motor if the rpms are set correctly and no safety switches are causing it to die...
Dec 26, 2013 | 13 HP Electric Start GX390
Where can i buy a gearbox that attaches to the honda GX390 QAE2
General Pump and Annovi Reverberi make them... among others I guess. Usually in shaft sizes 1" or 1 1/8" shafts x 2 15/16" if that matches your type. Bolt patterns are universal. a google search should give you several options.
Oct 18, 2012 | Honda 13 HP with Electric Start GX390-QAE2
Honda gx390 keeps cutting out
Linda, Sounds as though the engine is starving for fuel.
Sep 17, 2012 | 13 HP Electric Start GX390
My 13.0 honda gx390 motor has no spark and will not start
try disconnecting the black wire which runs across under the fuel tank you should have spark.
Nov 15, 2011 | Simpson Taskmaster Industrial Gas Powered...
Trying to remove magneto on 1987 honda xr80 bike will not fire
first you need to get a fly wheel puller. then remove the nut in the middle of fly wheel,insert fly wheel puller,reverce thread,tighten pin and it will pop off fly wheel.when you put it back on remember to line up "woodruff key",its a little notch on fly wheel whitch lines up with a ridge on cam shaft. if you cant fix your problem and you have spark its probobly your coil and condencer.
Sep 05, 2009 | 1987 Honda XR 250 R
Where can I find an owners manual for a Black Max 8125/ Honda GX390 OHV generator? I searched Honda's site but not there, no black max site. My lawn guy pulled a wire off and I need to see where it is...
low oil sensor will not cause the motor not starting.
most likely is th ground wire.
you can try to attach that wire to any surface and try to start it. of it start, then you have to dis-assemble the head and find out where the wire should be attached.
if not, the wire is attached to a hot side. either way you have to dis-assemble the head.
http://www.honda-engines.com/engines_owners_manuals/ownersmanuals/gx390.htm
here is the site for the manual.
Apr 07, 2009 | Electrical Supplies
13 HP Electric Start GX390 Logo
110 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
