Question about Epson Stylus Office Bx630fw
Print has error message saying paper stuck but there isn't any in it but won't go passed the message if turned on and off Any idea how to reset
techman
  • 3130 Answers
SOURCE: Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Posted on Apr 23, 2006
websnail
  • 419 Answers
SOURCE: epson stylus office bx300f
Usually this indicates that there's a problem with one of the following:
  • Cartridges are incorrectly seated or incompatible with the printer
  • Cartridge chips are soiled, damaged or otherwise unreadable by the printer
  • The printhead carriage is unable to travel along the printer width properly due to a foreign object or some other obsctruction
Best thing to do is try removing the cartridges, clean the cartridges gently with a cotton bud or similar, then replace them.. And to check the movement of the printhead to see if there are any indications of halted movement, etc...
If all else fails you will need to contact an Epson service engineer to try and get some help.
Best of luck and hope this resolves your issue.
Posted on May 12, 2009
SOURCE: Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Posted on Jul 29, 2009
TimHuntJr
  • 88 Answers
SOURCE: When I turn on my Epson DX8400 it says that I have
take a look at the back of your printer there should be a panell that comes off if you can take that pannel off look in there there is most likely paper stuck back there not allowing your printer to spool
Posted on Dec 09, 2009
cns assoc
  • 677 Answers
SOURCE: Epson Stylus printer is connected, but will not
Found this on the Web. If you find helpful, pls rate me.
Here is the link for all the discussions regarding this error.
http://discussions.apple.com/thread.jspa?threadID=2199441
Welcome to Apple Discussions
Go to: Apple > System Preferences > Print & Fax > Print and reselect your printer in the Default printer: box near the bottom of the panel. Then next in the same Print & Fax preference panel, select Open Print Queue: and Delete all the Jobs in the Status box and try printing something again.
reply
have no idea exactly what that error means, but now I suspect that when you "Trashed the EPSON folder in HD\Library\Printers\Epson" you trashed an important part of the OS X and not the installed Epson software.
If you have a backup Time Machine, a backup clone or that file is still in the trash you need to restore it "HD/Library/Printers/Epson/InkjetPrinters2 or whatever" back to the correct location, run Repair Permissions and hope that fixes it. If not then backup all your files, because it seems like you may have to completely reinstall the OS X....
Good Luck.....
Posted on Mar 05, 2010
The printer makes a loud noise - message says an error has occured turn printer off see your documentation
that means u have paper stuck in the far end of your printer preventing the print head from moving all the way to the left
Aug 30, 2010 | Epson Stylus RX580 InkJet Photo Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
When I turn on my Epson DX8400 it says that I have a paper jam that I can't find. The print head cartridge container goes across to the left in its usual warm up sequence, then make this awful noise and...
Dec 09, 2009 | Epson Stylus DX8400 All-In-One InkJet...
I do'nt see any paper being jammed.
when the message appear? Turn on printer or starting to print? If message appear at beginning turn on printer is caused by "something " slip at paper feeder. But if it appear at start to print, it caused by chip error? Do you use CISS chip?
Jun 25, 2009 | Epson CX7800 Stylus Color All-In-One...
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
EPSON 9600
try to reset the settings in the printer panel inside the printer setup menu. try to choose the initialize all. then observe your printer operation.
manual for troubleshooting options OR check the manual here :
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14397&prodoid=19302859
Jul 06, 2008 | Epson Stylus Pro 9600 InkJet Printer
Print head jam
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Epson Stylus Office Bx630fw Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
