Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
I have a gleh1642fs4 model that drum will not spin?
    New Friend:
I have a GLEH16242 Frigidaire/Electrolux stacking washer/dryer. The main bearing went out on the washer. I did the expensive fix of replacing the outer drum/bearing assembly in hope of nothing going wrong. Everything went together well, but now it won't go into high speed spin. It does if I have no clothes in it, but as soon as I introduce clothes it only does the 'medium spin' but never advances to the high. I've changed shocks, confirmed the door switch is working properly and double checked level. Even placed it on a big thick sheet of plywood in hops of stabilizing it more. It does have a wobble to it when it starts spinning, but when it kicks into medium spin, is smooths out.
Posted on Mar 12, 2017
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin ยท Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Whirlpool cabrio model # wtw5500xw1. Horrible screeching noise when it goes into spin, then shuts off
Since I don't have the service manual for this model- I'm unsure if this is a direct drive motor to transmission or belt driven through pulleys.
In first scenario motor bearing is shot
Belt driven model, belt is worn or derailed from pulley
3rd reason, clothes could be stuck between spin drum and tub assembly, causing the spin drum to jam.
Mar 16, 2015 | Whirlpool Washing Machines
Lat2500aae We have a Maytag Performa, Model
it sounds like the shocks on the drum maybe failing. on this model the washing machine mother board is close to the outer drum. the out drum may have made contact with it. and not turning on the pump to let the water out.
Oct 06, 2013 | Washing Machines
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
Have an old hotpointdryer model no 9321w the drum will not spin when door is closed i have to move drum by hand to make it spin, is there a capacitor on this model or somthing else that starts the drum...
Yes there is a start capacitor on this model, it is usually located at the rear right of the inside of the cabinet, so you will need to gain access to the inside of the dryer.
Feb 19, 2011 | Hotpoint Dryers
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
Unit shimmy's across floor
Remove the two support bars from below the washer drum from the front as instructed in the installation manual
Jan 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Sounds like a Harley when it spins, still spins though.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is not a Harley inside your washer, it is the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drum won't spin, drains ok and agitator works fine
http://www.pcappliancerepair.com/model-display.php This site shows your lid switch. Just enter your model number. The lid switch is the usual suspect for your symptom.
May 09, 2009 | Washing Machines
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
54 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
