Question about HP Designjet 110plus nr InkJet Printer
Paper cutter not working - HP Designjet 110plus nr InkJet Printer
    Habit-Forming:
  • 46 Answers
Chenge the Paper cutter
Posted on Apr 19, 2014
I need a schematic for a Katsuda JMC4s Paper Cutter from Japan?
Hi
I had JMC III KATSUDA (SH290HOP-N) paper cutter and memory shown ERROR 2. Memory did not work. Please let me know if you have any idea to fix it. My email is
leonardprint@gmail.com
Thank you
Dec 29, 2014 | Office Equipment & Supplies
HP DesignJet 110 - will not move cutter after job is printed
for paper cut, you should see the printer properties, there you can fine Auto Cut paper Check box or some thing like that. Make the correct setting, then it will work.
Thanks & Good Luck
Iqbal
Jun 10, 2008 | HP Designjet 110plus nr InkJet Printer
Can I sharpen the blade on my paper cutter?
You can sharpen the blade on your paper cutter but since they can be hard to sharpen you are better off leaving this task for a professional.
Sep 29, 2013 | Office Equipment & Supplies
What is a paper cutter?
A paper cutter is meant to cut large pieces of paper in a perfectly straight way. The tool is about 30 cm large on each side. It will have a grid drawn on the surface or a ruler along the top. On the right is a blade and it is attached to one corner. The blade lifts up to cut straight edges wherever you wish to cut. There is also a finger guard as a protective feature.
Jan 17, 2013 | Office Equipment & Supplies
Can't find cutter. could it have fallen into machine. the clip that holds it is there. This happened after trying to clear a paper jam
Cutter unit having press & release system, by mistake its released, it might be fallen in paper bin.. You can see there is a cut at right side near blur lever,pull cutter bush up to there & load the cutter into cutter bush. Once hearing click sound manually confirm its fixed properly or not.. once its confirmed, push cutter in to park area, power on the printer..
Aug 01, 2012 | HP DesignJet 500 InkJet Printer
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
In the paper and quality options I have only sheet or CD/DVD to select from. Roll option is not showing
The Roll Paper button cuts, feeds and returns paper to the printing position when the automatic cutter is used. When held down for three seconds, it reverses the roll paper out of the printer. The cutter can make either one cut precisely between images, two cuts with a margin between images or no cuts. The driver lets you select which method you prefer. The Utility program has an alignment option for the cutter that you should use whenever you reinstall the cutter.
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 17, 2010 | Epson Stylus Photo 1400 Printer
My star tsp600 has stopped working properly. The auto cutter no longer works and the receipt paper does not advance fully.
You will need to take the printer in for a service. The cutter is Jammed and that causes the fault on the paper feed.
Aug 05, 2009 | Star Micronics TSP600 Thermal Printer
Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Aug 02, 2009 | Royal VF1012mx Shredder
Panasonic fax
If there is a cutter it might be defective,try to off the cutter.If the is no cutter check paper sensor.clean or replace it
Mar 06, 2009 | HP FAX 1250 Fax Machine (Black)
HP Designjet 110plus nr InkJet Printer Logo
66 people viewed this question
Seeker5211
Seeker5211
