Question about Car Audio & Video
Sound car i have problem with my sound car beacuse my sound is catch the engine my amplifier have make the noise with the engine can you help me pls thanks
  • 47 Answers
The problem u are havin is interferance.
make sure your rca's are run separate from the power lead, then check that you have a good earthing point and if you still get your problem then get your auternator looked at.
You can buy a ground loop isolator witch is around £5 this will filter out these noises
Hope this helps if so please rate :)
Posted on Apr 23, 2009
Hi I'm Wayne. Pls help me with my GA13DS engine
Check for a bad rocker arm and correct valve adjustment. Make sure cam timing is correct. Never try to retard or advance the cam timing.
May 16, 2017 | Cars & Trucks
Tip
Car amplifier noise
Noise in Audio:
  • If noise is a "whine" that goes up and down with engine speed, confirm that Amplifier and any other source unit (Radio, EQ, X-over, etc) is properly grounded.
  • A "clicking" or "popping" noise at a rate that follows engine speed is generally induced by vehicles ignition system. Confirm that the vehicle is equipped with resistor plugs and plug wires. Or, ignition system may need service.
  • Speaker and input wires should not be routed next to the wired that interconnect lights and other accessories/equipment.
  • If above steps do not improve/clear noise interference, the system should be checked by a professional mobile audio installer.
If this tip in any way helped you please do not forget to rate it, thanks.
on Feb 21, 2010 | Car Audio & Video
1.sounds making noise that comes along with the engine tune? 2.my mono amplifier got burned during installation, is this possible for repair?
keep the rca cords away from your power wires( +) and the remote lead. The rca cords have a tendency to pick up and reproduce alternator noise if you run them too close together. Generally you should run them on opposite sides of the car when wiring. hope that helps.
Dec 11, 2010 | Rockford Fosgate Punch P5002 Car Audio...
My car doesn't start. When I turn the key to start the car it makes a clicking noise and the lights in the car start flashing. I thought is was the battery but when I got a jump charge the engine still...
It sounds like the battery is bad, beacuse it wont even start with a jump. If possible take the battery off and take it to your local autoparts or even walmart car service, they will test the voltage on battery for free, from the description you are giving about the clicking sound pretty sure the battery is gone. good Luck.
Nov 01, 2010 | 2004 Chevrolet Impala
Why the amplifier is getting the sound of the engine att he spekers? while having the car with the engine running, you can clearly hear the engine noise on the speakers
There could be a number of issues
1. Grounding
2. Kinda speaker cables your using
Check your wireing and make sure this is not grounded to where it can be interfered by the engine.
Aug 17, 2010 | Majestic MA4200R Car Audio Amplifier
Hooking it up
Not to worry, if you visit any electrical shops you will get the right size of the EYE TAGS that will fit your amplifier connection. You can carry you amplifier along to check this out. I am sure with patience identify and connect, check the connection leads carefully and your amp will power on. OK. Good day
Jul 12, 2010 | Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2...
Sound car amplifier
this could be couple of reasons
no.1
check that you havent run the rca's down same side as power lead as this causes a whining sound
no.2
Check your earthing point make sure its suitable
no.3
Check your auternator maybe faulty
there is a easy solution to this and thats to by a rca ground loop isolator which filters out unwanted noises
heres one i found on ebay for £5 click here
Apr 23, 2009 | Car Audio & Video
Jensen Amplifier..4 x 50WRMS at 4 Ohms
This sounds like you need a ceramic noise suppression filter/ferrule on the Power line to the amp. You should be able to get a suitable one from most car audio shops. Hope this helps, please post again if you have trouble getting one :)
Mar 28, 2007 | Jensen A600HLX Car Audio Amplifier
Audio system makes extra noises... pops
Check all the wiring. It could be a loose connection since it's intermitent. Really pay attention to the power cable, both the end for the amp and the one that's going to the battery cable.
Sep 05, 2006 | AudioBahn A8002T Car Audio Amplifier
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
